CISCO 1921/K9 Booting Issue
This is the Error i got while booting, It is a new router. The router is not going beyond "*Nov 16 10:53:21.683: %LINEPROTO-5-UPDOWN: Line protocol on Interface Embedded-Service-Engine0/0, changed state to down"
IOS Image Load Test
___________________
Digitally Signed Release Software
program load complete, entry point: 0x81000000, size: 0x481ac1c
Self decompressing the image :        ################################################################################        ################################################################################        ################################################################################        ################################################################################        ###################################################################################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
    TYPE      MEMORY_REQ
    Onboard devices &
    buffer pools      0x01E8F000
               TOTAL:      0x01E8F000
Rounded IOMEM up to: 32MB.
Using 6 percent iomem. [32MB/512MB]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.4(3)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 05-Jun-15 12:31 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 491520K/32768K bytes of memory.
Processor board ID XXXXXXXXX
2 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
250864K bytes of USB Flash usbflash0 (Read/Write)
Press RETURN to get started!
*Jan  2 00:00:02.395: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c1900 Next reboot level = ipbasek9 and License = ipbasek9
*Nov 16 10:53:00.171: c3600_scp_set_dstaddr2_idb(184)add = 80 name is Embedded-Service-Engine0/0
*Nov 16 10:53:05.095: %CTS-6-ENV_DATA_START_STATE: Environment Data Download in start state
*Nov 16 10:53:11.119: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to down
*Nov 16 10:53:11.119: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
*Nov 16 10:53:12.119: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
*Nov 16 10:53:12.123: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
*Nov 16 10:53:16.251: %USBFLASH-5-CHANGE: usbflash0 has been inserted!
*Nov 16 10:53:18.551: %SYS-5-LOG_CONFIG_CHANGE: Buffer logging: level warnings,xml disabled, filtering disabled, size (51200)
*Nov 16 10:53:18.707: %SYS-5-CONFIG_I: Configured from memory by console
*Nov 16 10:53:20.043: %SYS-5-RESTART: System restarted --
*Nov 16 10:53:20.051: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Nov 16 10:53:20.683: %LINK-5-CHANGED: Interface Embedded-Service-Engine0/0, changed state to administratively down
*Nov 16 10:53:20.683: %LINK-5-CHANGED: Interface GigabitEthernet0/1, changed state to administratively down
9 Replies 9
Deepak Kumar
Have you configured this device? Is it in production?
If not then change confreg to 0x2142 (You have to break normal boot process for entering in the rommon mode). Once that's done a reboot should see the router come up no problem.
ROMMON1>confreg 0x2142
ROMMON2>boot
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi Deepak,
IT is an standby router not connected to the network, Tried to break into ROMMN mode but it is again trying to boot and stopping at "*Nov 16 10:53:21.683: %LINEPROTO-5-UPDOWN: Line protocol on Interface Embedded-Service-Engine0/0, changed state to down"
Leo Laohoo
Post the complete output to the following commands:
1. sh version;
2. sh inventory; and
3. sh ip interface brief
Hi Leo Laohoo,
 This is the New router, Removed the cover and connected the console cable to configure but it is ending up with the line "%LINEPROTO-5-UPDOWN: Line protocol on Interface Embedded-Service-Engine0/0, changed state to down".
Hi Leo Laohoo,
I want to see the output I've requested otherwise I don't know how we can help.
gaston.benitez
Hi.
Some questions.
Does this device boots completely? or it continues booting in a loop?
Does this device has some modules? please try removing them and then try again.
BR
Gaston
Is there an image on the flash?  if this is new then I think that there should be.  Allow the unit to reload twelve times.  If there is any image on the flash, the device should boot to it.  Yes, I know it is a pain to wait for so long.  There may be a statement to an image that isn't on the flash: and it takes this long for it to determine that the image is not there.  You can, on some routers, remove the flash from the router and connect it to a PC an look at the filesystem and if necessary add a bootable image.  Also, if the flash: doesn't open, then you can replace it, if necessary, adding a bootable image.
Joe
saravanan93
hello,
remove flash from router,
try to connect the flash to your pc
download recommend IOS version for 1921 router
go into flash,delete the IOS file that was in inside the flash by default
copy the recommend IOS into the flash & try to connect flash to router and try boot,
