Setting up ARIN network range on a router. BGP setup and how do I use my IPs?
badassmexican
I'm very new to Cisco routing.  I have a 7100 series router and a new ISP that will advertise our IP block.
I'm trying to figure out how to configure the router to allow us to use the IPs from our block.  Any pointers on what I'm missing would be greatly appreciated.  I'm having lots of fun with this router.
I was able to figure out how to get the router setup and now I have internet and DHCP working.
It has two ports which I assigned with the IP provided by my ISP and an internal IP.
I added my ISP gateway as a neighbor in my BGP settings:
neighbor 33.88.245.169 remote-as 174
I also added a route to my ISPs gateway and the Internet started working:
ip route 0.0.0.0 0.0.0.0 38.88.245.169
I also created a new access list 1.  4 was already there so I'm thinking maybe I should not have created a new one and just added to access list 4.
I bolded the things I've added to the configuration.  The rest was already there.  I think this router was already working but with a different ISP.
Router#show running-config
Building configuration...
Current configuration : 3151 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname Router
logging rate-limit console 10 except errors
ip subnet-zero
no ip finger
no ip domain-lookup
ip dhcp excluded-address 192.168.250.0 192.168.250.6
ip dhcp pool Main-DHCP
network 192.168.250.0 255.255.255.0
default-router 192.168.250.1
dns-server 66.28.0.45
call rsvp-sync
interface FastEthernet0/0
ip address 192.168.250.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
description Uplink
ip address 38.88.245.170 255.255.255.248
ip nat outside
duplex full
speed 100
interface Serial1/0
no ip address
shutdown
framing c-bit
cablelength 10
dsu bandwidth 44210
router bgp 6551
bgp log-neighbor-changes
network 207.182.96.0
network 207.182.97.0
network 207.182.98.0
network 207.182.99.0
network 207.182.100.0
network 207.182.104.0
network 207.182.105.0
ip nat inside source list 1 interface FastEthernet0/1 overload
ip nat inside source list 4 interface FastEthernet0/1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
ip route 207.182.96.0 255.255.255.0 FastEthernet0/0
ip route 207.182.97.0 255.255.255.0 FastEthernet0/0
ip route 207.182.98.0 255.255.255.0 FastEthernet0/0
ip route 207.182.98.0 255.255.255.128 FastEthernet0/0
ip route 207.182.99.0 255.255.255.0 FastEthernet0/0
ip route 207.182.100.0 255.255.255.0 FastEthernet0/0
ip route 207.182.101.0 255.255.255.0 FastEthernet0/0
ip route 207.182.102.0 255.255.255.0 FastEthernet0/0
ip route 207.182.103.0 255.255.255.0 FastEthernet0/0
ip route 207.182.104.0 255.255.255.0 FastEthernet0/0
ip route 207.182.105.0 255.255.255.0 FastEthernet0/0
no ip http server
ip prefix-list USCOLO_out seq 10 permit 207.182.96.0/24
ip prefix-list USCOLO_out seq 11 permit 207.182.96.0/19
ip prefix-list USCOLO_out seq 20 permit 207.182.97.0/24
ip prefix-list USCOLO_out seq 30 permit 207.182.98.0/24
ip prefix-list USCOLO_out seq 40 permit 207.182.99.0/24
ip prefix-list USCOLO_out seq 41 permit 207.182.100.0/24
ip prefix-list USCOLO_out seq 42 permit 207.182.104.0/24
ip prefix-list USCOLO_out seq 45 permit 207.182.105.0/24
ip prefix-list USCOLO_out seq 99 deny 0.0.0.0/0
ip prefix-list default seq 5 permit 0.0.0.0/0
logging facility local0
logging source-interface FastEthernet0/0
access-list 1 permit 192.168.250.0 0.0.0.255
access-list 4 permit 207.182.105.0
access-list 4 permit 207.182.104.0
access-list 4 permit 207.182.97.0
access-list 4 permit 207.182.96.0
access-list 4 permit 207.182.99.0
access-list 4 permit 207.182.98.0
access-list 4 permit 207.182.100.0
route-map USCOLO permit 10
match as-path 1
set local-preference 103
route-map USCOLO_out permit 10
match ip address prefix-list USCOLO_out
line con 0
transport input none
line aux 0
line vty 0 4
login
line vty 5 15
login
end
39 Replies 39
Here's what I get from those two commands:
Router#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set
33.0.0.0/29 is subnetted, 1 subnets
C 33.88.245.168 is directly connected, FastEthernet0/1
C 192.168.250.0/24 is directly connected, FastEthernet0/0
Router#sh ip bgp sum
BGP router identifier 192.168.250.1, local AS number 6551
BGP table version is 1, main routing table version 1
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
33.88.245.169 4 174 0 0 0 0 0 never Active
I see my gateway of last resort isn't set and that my BGP router identifier is my internal IP instead of the IP that was assigned to me by my ISP.
I have time to test today so I'll compare my configs that had me pinging the gateway and online with this one.
Hello
You don’t have any bgp peering to  33.88.245.169
Can ping that address?
Kind Regards
Paul
I don't seem to be able to ping it.  But it doesn't show a success rate is 0 percent message.  So I'm not sure.
When I switched back to my old config I also wasn't able to ping it but I was able to get online with DHCP.
Router#ping 33.88.245.168
Sending 5, 100-byte ICMP Echos to 33.88.245.168, timeout is 2 seconds:
Router#
Router#ping 33.88.245.169
Sending 5, 100-byte ICMP Echos to 33.88.245.169, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#
Router#sh ip route
Current configuration : 2023 bytes
version 12.1
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
hostname Router
logging console critical
aaa new-model
aaa authentication login LOCAL local
aaa authorization console
ip subnet-zero
no ip source-route
no ip gratuitous-arps
no ip icmp rate-limit unreachable
ip cef
no ip finger
ip tcp synwait-time 5
no ip domain-lookup
no ip bootp server
call rsvp-sync
ip nat inside
duplex auto
speed auto
ip address 33.88.245.170 255.255.255.248
ip nat outside
duplex full
speed 100
interface Serial1/0
no ip address
shutdown
framing c-bit
cablelength 10
dsu bandwidth 44210
router bgp 6551
no synchronization
neighbor 33.88.245.169 route-map allowdefault in
neighbor 33.88.245.169 filter-list 5 out
no auto-summary
ip nat pool LAN-POOL 207.182.96.1 207.182.96.254 prefix-length 24 type match-hot
ip classless
no ip http server
ip as-path access-list 5 permit ^$
ip prefix-list 1 seq 5 permit 0.0.0.0/0
ip access-list extended cbac
permit icmp any any echo-reply
permit tcp any any eq bgp
permit udp any any eq bootpc
permit udp any any eq snmp
permit tcp any any established
deny   ip any any
logging trap debugging
logging facility local2
access-list 10 permit 192.168.250.0 0.0.0.255
no cdp run
route-map allowdefault permit 10
match ip address prefix-list 1
route-map LAN permit 10
match ip address 10
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
login authentication LOCAL
line aux 0
privilege level 15
logging synchronous
transport output telnet
line vty 5 15
end
I finally made some progress on this and can ping the gateway from the router and BGP is working. I had some wrong IPs in the configuration.  I also added a default route and it seemed to do the trick.
This command seemed like it was going to do some nat translating but I didn't have reversible available just overload and <cr>.  So I tried overload.
ip nat inside source route-map LAN pool LAN-POOL reversible
But it didn't seem to do the trick for mapping the internal to the external IP's.
I set my client up with these settings and I can't seem to ping anything from the client:
ip: 192.168.250.100
mask: 255.255.255.0
gateway: 192.168.250.1
DNS: 66.28.0.45
Am I using the right settings for my clients?
Parts of these commands also weren't available:
*security authentication failure rate 10 log
*security passwords min-length 6
*username commsadmin privilege 15 secret xxxxxxxx
(secret wasn't available but password was)
*login block-for 10 attempts 2 within 5
(no login just logging)
*no ipv6 cef
(no ipv6)
*no cdp log mismatch duplex
(log not available just advertise-v2, holdtime, timer, run)
*no ip http secure-server
(secure-server not available just access-class, authentication, path, port ,server)
*crypto key generate rsa label LOCAL general-keys modulus 2048
(no crypto)
*ip ssh version 2
*ip ssh authentication-retries 3
(no ssh)
*ip inspect audit-trail
*ip inspect udp idle-time 1800
*ip inspect dns-timeout 7
*ip inspect tcp idle-time 14400
*ip inspect name CBAC ftp timeout 3600
*ip inspect name CBAC http timeout 3600
*ip inspect name CBAC rcmd timeout 3600
*ip inspect name CBAC realaudio timeout 3600
*ip inspect name CBAC smtp timeout 3600
*ip inspect name CBAC tftp timeout 30
*ip inspect name CBAC udp timeout 15
*ip inspect name CBAC tcp timeout 3600
*ip inspect CBAC out
(no inspect)
Router#sh ip bgp summary
BGP router identifier 38.88.245.170, local AS number 6551
BGP table version is 2, main routing table version 2
1 network entries and 1 paths using 133 bytes of memory
1 BGP path attribute entries using 60 bytes of memory
1 BGP AS-PATH entries using 24 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP activity 1/0 prefixes, 1/0 paths, scan interval 15 secs
38.88.245.169   4   174      10       9        2    0    0 00:06:19        1
Router#show ip bgp
BGP table version is 2, local router ID is 38.88.245.170
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 0.0.0.0          38.88.245.169                          0 174 i
Router#sh run
Current configuration : 2071 bytes
version 12.1
hostname Router
aaa new-model
ip subnet-zero
no ip finger
call rsvp-sync
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
duplex auto
speed auto
description Wilshire
ip access-group cbac in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex full
speed 100
interface Serial1/0
no ip address
shutdown
framing c-bit
cablelength 10
dsu bandwidth 44210
router bgp 6551
no synchronization
neighbor 38.88.245.169 remote-as 174
Router#sh run
Current configuration : 2046 bytes
version 12.1
hostname Router
aaa new-model
ip subnet-zero
no ip finger
call rsvp-sync
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
duplex auto
speed auto
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex full
speed 100
interface Serial1/0
no ip address
shutdown
framing c-bit
cablelength 10
dsu bandwidth 44210
router bgp 6551
no synchronization
neighbor 38.88.245.169 route-map allowdefault in
neighbor 38.88.245.169 filter-list 5 out
no auto-summary
ip nat pool LAN-POOL 207.182.96.1 207.182.96.254 prefix-length 24 type match-host
ip nat inside source route-map LAN pool LAN-POOL overload
ip classless
no ip http server
deny ip any any
no cdp run
match ip address 10
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
privilege level 15
logging synchronous
line vty 5 15
end
Hello
Your isp needs to be know about 207.182.x.x/19 range you state you want to use for NAT if that range isn't applicable then it wont route for it, Hence why I queried this ip range previously.
Kind Regards
Paul
I will verify with my ISP that the range 207.182.x.x/19 is applicable.  I'm pretty sure it is but I will double check to make sure.
I was able to ping the gateway, router and DNS server from my client but I couldn't get internet to work.  I'll keep tinkering with it.
Also, is this all of the NAT configuration to map my internal 192.168.250.0 network to the 207.182.100.0 ?  Will it work with out the "reverse" option.
ip nat pool LAN-POOL 207.182.100.1 207.182.100.254 prefix-length 24 type match-host
match ip address 10
Hello
You NAT config is now fine just verify that nat pool ip range is applicable with your isp
Kind Regards
Paul
I can finally use a static IP provided by my ISP... thank you so much.
I added this line to my config and it worked when I use the .7 ip:
ip nat inside source static 207.182.100.7 38.88.245.174
I removed this line and it is still working:
no ip nat pool ISP_BLOCK 38.88.245.169 38.88.245.174 netmask 255.255.255.248
no ip nat inside source list 1 pool ISP_BLOCK
Still trying to figure out how to use the external IP internally and and my ARIN block.
Been learning a lot.
This is finally working!  Thank you so much for all your help.  I can use all the IPs now!
I'm not sure if the ISP changed anything or if it was this command I found:
clear ip bgp * soft in
Here's my config... I'm still deleting things and reading up to understand if I need them or not.
Next step is the route-map entries.
Router#sh run
Current configuration : 5544 bytes
version 12.1
hostname Router
ip subnet-zero
no ip finger
no ip domain-lookup
call rsvp-sync
ip address 207.182.100.1 255.255.255.0 secondary
ip address 207.182.96.1 255.255.255.0 secondary
ip address 207.182.97.1 255.255.255.0 secondary
ip address 207.182.99.1 255.255.255.0 secondary
ip address 207.182.101.1 255.255.255.0 secondary
ip address 207.182.102.1 255.255.255.0 secondary
ip address 207.182.103.1 255.255.255.0 secondary
ip address 207.182.104.1 255.255.255.0 secondary
ip address 207.182.105.1 255.255.255.0 secondary
ip address 207.182.106.1 255.255.255.0 secondary
ip address 207.182.107.1 255.255.255.0 secondary
ip address 207.182.108.1 255.255.255.0 secondary
ip address 207.182.109.1 255.255.255.0 secondary
ip address 207.182.110.1 255.255.255.0 secondary
ip address 207.182.111.1 255.255.255.0 secondary
ip address 207.182.112.1 255.255.255.0 secondary
ip address 207.182.113.1 255.255.255.0 secondary
ip address 207.182.114.1 255.255.255.0 secondary
ip address 207.182.115.1 255.255.255.0 secondary
ip address 207.182.116.1 255.255.255.0 secondary
ip address 207.182.117.1 255.255.255.0 secondary
ip address 207.182.118.1 255.255.255.0 secondary
ip address 207.182.119.1 255.255.255.0 secondary
ip address 207.182.120.1 255.255.255.0 secondary
ip address 207.182.121.1 255.255.255.0 secondary
ip address 207.182.122.1 255.255.255.0 secondary
ip address 207.182.123.1 255.255.255.0 secondary
ip address 207.182.124.1 255.255.255.0 secondary
ip address 207.182.125.1 255.255.255.0 secondary
ip address 207.182.126.1 255.255.255.0 secondary
ip address 207.182.127.1 255.255.255.0 secondary
ip address 207.182.98.1 255.255.255.0
ip nat inside
duplex auto
speed auto
description Uplink
ip nat outside
duplex full
speed 100
interface Serial1/0
no ip address
shutdown
framing c-bit
cablelength 10
dsu bandwidth 44210
router bgp 6551
network 207.182.101.0
network 207.182.102.0
network 207.182.103.0
network 207.182.106.0
network 207.182.107.0
network 207.182.108.0
network 207.182.109.0
network 207.182.110.0
network 207.182.111.0
network 207.182.112.0
network 207.182.113.0
network 207.182.114.0
network 207.182.115.0
network 207.182.116.0
network 207.182.117.0
network 207.182.118.0
network 207.182.119.0
network 207.182.120.0
network 207.182.121.0
network 207.182.122.0
network 207.182.123.0
network 207.182.124.0
network 207.182.125.0
network 207.182.126.0
network 207.182.127.0
neighbor 38.88.245.169 update-source FastEthernet0/1
neighbor 38.88.245.169 version 4
neighbor 38.88.245.169 prefix-list USCOLO_out out
ip classless
no ip http server
ip prefix-list USCOLO_out seq 109 permit 207.182.96.0/24
ip prefix-list USCOLO_out seq 114 permit 207.182.98.0/24
ip prefix-list USCOLO_out seq 119 permit 207.182.97.0/24
ip prefix-list USCOLO_out seq 124 permit 207.182.99.0/24
ip prefix-list USCOLO_out seq 129 permit 207.182.100.0/24
ip prefix-list USCOLO_out seq 134 permit 207.182.101.0/24
ip prefix-list USCOLO_out seq 139 permit 207.182.102.0/24
ip prefix-list USCOLO_out seq 144 permit 207.182.103.0/24
ip prefix-list USCOLO_out seq 149 permit 207.182.104.0/24
ip prefix-list USCOLO_out seq 154 permit 207.182.105.0/24
ip prefix-list USCOLO_out seq 159 permit 207.182.106.0/24
ip prefix-list USCOLO_out seq 164 permit 207.182.107.0/24
ip prefix-list USCOLO_out seq 169 permit 207.182.108.0/24
ip prefix-list USCOLO_out seq 174 permit 207.182.109.0/24
ip prefix-list USCOLO_out seq 179 permit 207.182.110.0/24
ip prefix-list USCOLO_out seq 184 permit 207.182.111.0/24
ip prefix-list USCOLO_out seq 189 permit 207.182.112.0/24
ip prefix-list USCOLO_out seq 194 permit 207.182.113.0/24
ip prefix-list USCOLO_out seq 199 permit 207.182.114.0/24
ip prefix-list USCOLO_out seq 204 permit 207.182.115.0/24
ip prefix-list USCOLO_out seq 209 permit 207.182.116.0/24
ip prefix-list USCOLO_out seq 214 permit 207.182.117.0/24
ip prefix-list USCOLO_out seq 219 permit 207.182.118.0/24
ip prefix-list USCOLO_out seq 224 permit 207.182.119.0/24
ip prefix-list USCOLO_out seq 229 permit 207.182.120.0/24
ip prefix-list USCOLO_out seq 234 permit 207.182.121.0/24
ip prefix-list USCOLO_out seq 239 permit 207.182.122.0/24
ip prefix-list USCOLO_out seq 244 permit 207.182.123.0/24
ip prefix-list USCOLO_out seq 249 permit 207.182.124.0/24
ip prefix-list USCOLO_out seq 254 permit 207.182.125.0/24
ip prefix-list USCOLO_out seq 259 permit 207.182.126.0/24
ip prefix-list USCOLO_out seq 264 permit 207.182.127.0/24
match as-path 1
line con 0
line aux 0
line vty 0 4
login
line vty 5 15
login
end
