SFP-GE-L and WS-SUP32-8GE-3B
rmv72
I've router 7604 with WS-SUP32-8GE-3B.
Can i use that module?
SFP-GE-L=
1000BASE-LX/LH SFP transceiver module for MMF and SMF, 1300-nm wavelength, extended operating temperature range and DOM support
GLC-LH-SM and SPF-GE-L are both consider small form pluggable module (not to confuse with the part number). The other type of module is call GBIC.
Please take a look at figure 2 in the following link:
http://www.cisco.com/en/US/docs/routers/7200/install_and_upgrade/gbic_sfp_modules_install/5067g.html#wp90313
HTH,
jerry
5 Replies 5
Mark Yeates
Level 7
Level 7
Mike,
I don't think that SFP is supported in that particular card. Please see the DOM compatibility matrix.
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_8031.html
Mark
Jerry Ye
SFP-GE-L= is not support on the WS-SUP32-8GE-3B. However, GLC-LH-SM= has similar spec - 1000BASE-LX/LH SFP transceiver module for MMF and SMF, 1300-nm wavelength.
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
HTH,
jerry
Hi!
But WS-SUP32-8GE-3B don't have place for GLC-LH-SM, only for SFP. Am i correct?
You can use the GLC-LH-SM SFP but not the SFP-GE-L SFP. The WS-SUP32-8GE-3B does not support DOM SFP modules like the SFP-GE-L.
http://www.cisco.com/en/US/products/hw/modules/ps4999/products_tech_note09186a00807a30d6.shtml#support1
HTH,
Mark
HTH,
jerry
