SG-350-28MP Setup up static route
Altronics
Setup Static Route in the switch and use DHCP server in the router, not the switch
OK, what you need to know
Good luck
KB
How to set it up.
to configure static routes in SG switches, check below guide. also need to know your router model to share specific DHCP configuration
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-300-series-managed-switches/smb63-ipv4-static-route-setup-on-the-300-series-managed-switches.html
Good luck
KB
balaji.bandi
As i understand you would like to use this device as DHCP server and route the traffic using different device ? is this correct ?
Follow below video for DHCP Server config - change the router to different IP where you looking to route for the device
https://www.youtube.com/watch?v=B3QLZaCdwVE
BB
