sh ip interface brief
shivaram840
Community Member
Hi folks,
we have recently configured 3925 ISR router with T1 circuits. Everything is working normally
but when i give a command show ip interface brief
i could found my serials interfaces are showing unset even after reboot the router
Interface                      IP-Address        OK?         Method          Status                          Protocol
Embedded- /0            unassigned        YES          NVRAM     administratively down   down
GigabitEthernet0/0  10.210.23.129   YES           NVRAM          down                           down
GigabitEthernet0/1   10.210.23.129  YES           NVRAM             up                              up
GigabitEthernet0/2    unassigned       YES           NVRAM      administratively down down
Serial0/0/0:0              unassigned       YES            unset                 up                              up
Serial0/0/1:0              unassigned       YES            unset                 up                              up
Serial0/1/0:0              unassigned       YES            unset                 up                              up
Serial0/1/1:0              unassigned       YES             unset                up                              up
Multilink1                 10.10.10.1          YES             NVRAM             up                              up
please give me a clarify on this one ? is there any risk factor ?
any commands would i missed ?
Shiva
Georg Pauwen
Hello Shiva,
method 'unset' refers to the method the serial interfaces obtain an IP address. Since you have not configured anything, the method is 'unset'. If you would configure e.g. 'ip address dhcp' you would see 'DCHP' in the method field.
Here is an excerpt from Cisco doc:
The method field has the following possible values:
•RARP or SLARP—Reverse Address Resolution Protocol (RARP) or Serial Line Address Resolution Protocol (SLARP) request
•BOOTP—Bootstrap protocol
•TFTP—Configuration file obtained from TFTP server
•manual—Manually changed by CLI command
•NVRAM—Configuration file in NVRAM
•IPCP—ip address negotiated command
•DHCP—ip address dhcp command
•unassigned—No IP address
•unset—Unset
•other—Unknown
Hi gpauwen,
below results are from other router but we havent configured any ip addrress on serial interface but still it is showing method is NVRAM
what could the issue.
GigabitEthernet0/0         167.228.170.130 YES                 NVRAM                    up                             up
GigabitEthernet0/1         unassigned              YES              NVRAM         administratively down   down
Serial0/0/0:0                    unassigned              YES               NVRAM                     up                          up
Serial0/0/1:0                    unassigned              YES               NVRAM                      up                         up
Serial0/1/0:0                    unassigned              YES               NVRAM                       up                         up
Serial0/1/1:0                    unassigned              YES               NVRAM                       up                         up
Multilink1                         10.10.10.2                YES               NVRAM                      up                          up
Shiva
