show tech-support
zaqtivi
how can we print only the 'show running-config' of show tech-support ?
Use
"show running-config | redirect tftp://your.ftp.server/your-file-name"
to redirect the output to file on tftp server and then you can print the file.
//Mikhail Galiulin
If you are using Hyperterminal or Putty you can easily capture the text into a file! In hyperterminal just before giving the command 'Show running-config' click on
Transfer->Capture Text->File name!
Else in Putty, you can change the settings in Session->Logging->Log all session output.
After modifying these settings, you can capture the output of any command you want!
Hope this helps!
AbhisheK
Please rate all helpful posts!!!
