Simple access list question
whiteford
On a router I have added:
line vty 0 4
access-class 50 in
and i was wondering if I can add an IP range for the access-list 50?
At the moment I just do:
access-list 50 permit 172.19.1.10
access-list 50 permit 172.19.1.11
access-list 50 permit 172.19.1.12
Can I do something like:
access-list 50 permit 172.19.1.10-15?
mahmoodmkl
Level 7
Level 7
U can use the wildcard masks to provide the range for the IP's.What is the subnet mask fot this IP's
Mahmood
Hi, it's:
255.255.255.0
paul.matthews
Level 5
Level 5
10-50 would be awkward. You can use wildcards
access-list 50 permit 172.19.1.8 0.0.0.7 would permit 8-15, it all depends on exactly what addresses you need to permit, what the consequences of allowing a couple extra are compared to the convenience of a single entry.
If you really must do 10-15, with no others, try:
access-list 50 permit 172.19.1.10 0.0.0.1
access-list 50 permit 172.19.1.12 0.0.0.3
Where the first permits 10 & 11, and the second prmits 12-15
