Site to Site VPN behind NAT with Cisco 871 router
GlobalRisk
I need to set up a site to site VPN with a Cisco 871 on one side behind a NAT router. Ports 500 and 4500 are forwarded to the 871 router. This should be a fairly standard configuration. The above diagram shows everything for clarity.
If the 871 VPN router was the public router, this would be fairly straight forward with a crypto map. So far I've tried that, but from "show crypto isakmp sa", it looks like it is stuck in the MM_KEY_EXCH. I'm guessing that this may be a mismatch in the identity. Perhaps the router is comparing the private address instead of the public address.
Example output of show crypto isakmp sa:
dst: 100.1.1.1
src: 10.30.1.2
state: MM_KEY_EXCH
Relevant configuration on 871:
crypto isakmp key keyhere address 100.1.1.1
crypto ipsec transform-set vpnts esp-aes 256 esp-sha-hmac
crypto map vpnmap 1 ipsec-isakmp
    set peer 100.1.1.1
    set transform-set vpnts
    match address aclforthisvpn
What am I missing to get this to communicate over the NAT?
21 Replies 21
The Issue is VPN router not this 871,
can you share the config of it?
Unfortunately I don't have that configuration. Essentially it's configured with peer as 200.2.1.1 (public address of site B) and the interesting traffic from 10.10.1.0/24 (site A) to 10.20.2.0/24 (site B). I can recommend any changes, but I don't have direct access to that side. I can change anything on the 871 side.
Only make him change the crypto isakmp key address 200.2.1.1
i think that will work,
also can I see show crypto isakmp sa detail, and crypto ipsec  sa
I want to check if both side agree to use NAT-t.
I asked them to verify the configuration on their side, especially the crypto isakmp key command or their equivalent. I don't know what type of device they have.
Here is the output from show crypto isakmp sa detail:
Codes: C - IKE configuration mode, D - Dead Peer Detection
       K - Keepalives, N - NAT-traversal
       X - IKE Extended Authentication
       psk - Preshared key, rsig - RSA signature
       renc - RSA encryption
IPv4 Crypto ISAKMP SA
C-id  Local           Remote          I-VRF    Status Encr Hash Auth DH Lifetime Cap.
2226  10.30.1.2       100.1.1.1                ACTIVE aes  sha  psk  2  0        DN
       Engine-id:Conn-id =  SW:226
Output from show crypto ipsec sa:
interface: FastEthernet4
    Crypto map tag: vpnmaps, local addr 10.30.1.2
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
   remote ident (addr/mask/prot/port): (10.10.1.115/255.255.255.255/0/0)
   current_peer 100.1.1.1 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 38, #recv errors 0
     local crypto endpt.: 10.30.1.2, remote crypto endpt.: 100.1.1.1
     path mtu 1500, ip mtu 1500, ip mtu idb FastEthernet4
     current outbound spi: 0x0(0)
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
from my view the router is not using NAT-T and hence failed.
enable NAT-T in your router
crypto ipsec nat-transparency udp-encapsulation
I thought of that. But, isn't that enabled by default. I added the command anyway, but it hasn't made a difference. I do see in the log a reference to NAT-T. I'll try to post the log.
The output of show crypto ipsec sa is interesting. In my experience you get output like this only when the ISAKMP negotiation was successful and the IPSEC negotiation is successful. the output does indicate that no traffic is flowing over the VPN (pkts encap pkts decaps are both zero). I have seen this symptom (caps and decaps are zero) when there were issues with routing logic or issues with address translation, and I am sure that there might be other causes. Before we can give much more advice we will need to see the configuration of the router (with Public IP and any other sensitive information masked).
Rick
Do you have access to the ISP router NAT configuration? If you do, please share the part of config related with the Cisco 871 (you can alias IP addresses with private IP addresses). Also, please share the whole configuration on 871 related with the IPSec (including the ACL defining the interesting traffic, all crypto ipsec commands, ...).
HTH,
Meheretab
I have full access to the ISP router. There is nothing special here. It is just a generic Xfinity router with standard NAT. The only specific configuration is the forwarding of ports 500 and 4500. I can see the requests hitting the 871 router, so I know the port forwarding is working.
shut/no shut the WAN interface on the 871 and post the output of:
debug crypto isakmp
debug crypto ipsec
Hello
Need to make sure both rtrs are NAT-T capable , what ios versions are currenlty running on them or at least the 871?
Kind Regards
Paul
The 871 is running Version 12.4(15)T6. I don't know about the other router.
Okay
Then that rtr is NAT-T capable (above 12.2(13)T, now if the other rtr isn't then it could be the reason why the s2s vpn isn't working.
Lastly can you confirm you have a crypto policy created?
Kind Regards
Paul
GlobalRisk
Debug output for isakmp:
Dec  3 19:46:54.845: ISAKMP:(2445): retransmitting phase 1 MM_KEY_EXCH...
Dec  3 19:46:54.845: ISAKMP (0:2445): incrementing error counter on sa, attempt 4 of 5: retransmit phase 1
Dec  3 19:46:54.845: ISAKMP:(2445): sending packet to 100.1.1.1 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
Dec  3 19:46:54.845: ISAKMP:(2445):Sending an IKE IPv4 Packet.
Dec  3 19:47:00.387: ISAKMP:(0): SA request profile is (NULL)
Dec  3 19:47:00.387: ISAKMP: Created a peer struct for 100.1.1.1, peer port 500
Dec  3 19:47:00.387: ISAKMP: New peer created peer = 0x839D81EC peer_handle = 0x8000069D
Dec  3 19:47:00.387: ISAKMP: Locking peer struct 0x839D81EC, refcount 1 for isakmp_initiator
Dec  3 19:47:00.387: ISAKMP: local port 500, remote port 500
Dec  3 19:47:00.387: ISAKMP: set new node 0 to QM_IDLE
Dec  3 19:47:00.387: ISAKMP: Find a dup sa in the avl tree during calling isadb_insert sa = 83127C80
Dec  3 19:47:00.387: ISAKMP:(0):Can not start Aggressive mode, trying Main mode.
Dec  3 19:47:00.387: ISAKMP:(0):found peer pre-shared key matching 100.1.1.1
Dec  3 19:47:00.387: ISAKMP:(0): constructed NAT-T vendor-rfc3947 ID
Dec  3 19:47:00.387: ISAKMP:(0): constructed NAT-T vendor-07 ID
Dec  3 19:47:00.387: ISAKMP:(0): constructed NAT-T vendor-03 ID
Dec  3 19:47:00.391: ISAKMP:(0): constructed NAT-T vendor-02 ID
Dec  3 19:47:00.391: ISAKMP:(0):Input = IKE_MESG_FROM_IPSEC, IKE_SA_REQ_MM
Dec  3 19:47:00.391: ISAKMP:(0):Old State = IKE_READY  New State = IKE_I_MM1
Dec  3 19:47:00.391: ISAKMP:(0): beginning Main Mode exchange
Dec  3 19:47:00.391: ISAKMP:(0): sending packet to 100.1.1.1 my_port 500 peer_port 500 (I) MM_NO_STATE
Dec  3 19:47:00.391: ISAKMP:(0):Sending an IKE IPv4 Packet.
Dec  3 19:47:00.415: ISAKMP (0:0): received packet from 100.1.1.1 dport 500 sport 500 Global (I) MM_NO_STATE
Dec  3 19:47:00.415: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
Dec  3 19:47:00.415: ISAKMP:(0):Old State = IKE_I_MM1  New State = IKE_I_MM2
Dec  3 19:47:00.415: ISAKMP:(0): processing SA payload. message ID = 0
Dec  3 19:47:00.415: ISAKMP:(0): processing vendor id payload
Dec  3 19:47:00.415: ISAKMP:(0): vendor ID is DPD
Dec  3 19:47:00.415: ISAKMP:(0): vendor ID seems Unity/DPD but major 69 mismatch
Dec  3 19:47:00.415: ISAKMP (0:0): vendor ID is NAT-T RFC 3947
Dec  3 19:47:00.415: ISAKMP:(0): vendor ID seems Unity/DPD but major 201 mismatch
Dec  3 19:47:00.419: ISAKMP:(0):found peer pre-shared key matching 100.1.1.1
Dec  3 19:47:00.419: ISAKMP:(0): local preshared key found
Dec  3 19:47:00.419: ISAKMP : Scanning profiles for xauth ... sitebvpn
Dec  3 19:47:00.423: ISAKMP:(0):Checking ISAKMP transform 4 against priority 5 policy
Dec  3 19:47:00.423: ISAKMP:      encryption AES-CBC
Dec  3 19:47:00.423: ISAKMP:      keylength of 256
Dec  3 19:47:00.423: ISAKMP:      hash SHA
Dec  3 19:47:00.423: ISAKMP:      default group 2
Dec  3 19:47:00.423: ISAKMP:      auth pre-share
Dec  3 19:47:00.423: ISAKMP:      life type in seconds
Dec  3 19:47:00.423: ISAKMP:      life duration (VPI) of  0x0 0x1 0x51 0x80
Dec  3 19:47:00.423: ISAKMP:(0):atts are acceptable. Next payload is 0
Dec  3 19:47:00.423: ISAKMP:(0):Acceptable atts:actual life: 0
Dec  3 19:47:00.423: ISAKMP:(0):Acceptable atts:life: 0
Dec  3 19:47:00.423: ISAKMP:(0):Fill atts in sa vpi_length:4
Dec  3 19:47:00.423: ISAKMP:(0):Fill atts in sa life_in_seconds:86400
Dec  3 19:47:00.423: ISAKMP:(0):Returning Actual lifetime: 86400
Dec  3 19:47:00.423: ISAKMP:(0)::Started lifetime timer: 86400.
Dec  3 19:47:00.423: ISAKMP:(0): processing vendor id payload
Dec  3 19:47:00.423: ISAKMP:(0): vendor ID is DPD
Dec  3 19:47:00.423: ISAKMP:(0): vendor ID seems Unity/DPD but major 69 mismatch
Dec  3 19:47:00.423: ISAKMP (0:0): vendor ID is NAT-T RFC 3947
Dec  3 19:47:00.423: ISAKMP:(0): vendor ID seems Unity/DPD but major 201 mismatch
Dec  3 19:47:00.423: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
Dec  3 19:47:00.423: ISAKMP:(0):Old State = IKE_I_MM2  New State = IKE_I_MM2
Dec  3 19:47:00.427: ISAKMP:(0): sending packet to 100.1.1.1 my_port 500 peer_port 500 (I) MM_SA_SETUP
Dec  3 19:47:00.427: ISAKMP:(0):Sending an IKE IPv4 Packet.
Dec  3 19:47:00.427: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
Dec  3 19:47:00.427: ISAKMP:(0):Old State = IKE_I_MM2  New State = IKE_I_MM3
Dec  3 19:47:00.463: ISAKMP (0:0): received packet from 100.1.1.1 dport 500 sport 500 Global (I) MM_SA_SETUP
Dec  3 19:47:00.463: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
Dec  3 19:47:00.463: ISAKMP:(0):Old State = IKE_I_MM3  New State = IKE_I_MM4
Dec  3 19:47:00.467: ISAKMP:(0): processing KE payload. message ID = 0
Dec  3 19:47:00.511: ISAKMP:(0): processing NONCE payload. message ID = 0
Dec  3 19:47:00.511: ISAKMP:(0):found peer pre-shared key matching 100.1.1.1
Dec  3 19:47:00.511: ISAKMP:received payload type 20
Dec  3 19:47:00.511: ISAKMP (0:2447): NAT found, the node inside NAT
Dec  3 19:47:00.511: ISAKMP:(2447):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
Dec  3 19:47:00.511: ISAKMP:(2447):Old State = IKE_I_MM4  New State = IKE_I_MM4
Dec  3 19:47:00.511: ISAKMP:(2447):SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
Dec  3 19:47:00.511: ISAKMP (0:2447): ID payload
	next-payload : 8
	type         : 1
	address      : 10.30.1.2
	protocol     : 17
	port         : 0
	length       : 12
Dec  3 19:47:00.511: ISAKMP:(2447):Total payload length: 12
Dec  3 19:47:00.515: ISAKMP:(2447): sending packet to 100.1.1.1 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
Dec  3 19:47:00.515: ISAKMP:(2447):Sending an IKE IPv4 Packet.
Dec  3 19:47:00.515: ISAKMP:(2447):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
Dec  3 19:47:00.515: ISAKMP:(2447):Old State = IKE_I_MM4  New State = IKE_I_MM5
Dec  3 19:47:00.711: ISAKMP:(2446): retransmitting phase 1 MM_KEY_EXCH...
Dec  3 19:47:00.711: ISAKMP (0:2446): incrementing error counter on sa, attempt 2 of 5: retransmit phase 1
Dec  3 19:47:00.711: ISAKMP:(2446): sending packet to 100.1.1.1 my_port 500 peer_port 500 (R) MM_KEY_EXCH
Dec  3 19:47:00.711: ISAKMP:(2446):Sending an IKE IPv4 Packet.
