VPN sending MAC traffic
dannymcca
Still learning this so please bear with me.
I have set up a VPN between 2 routers that are connected over 2 ADSL lines and layer 3 traffic transmits and receives ok.
My problem is that i also need to transmit and receive layer 2 traffic and this is not happening the router is rejecting this and not forwarding down my dialer interface.
Please can you help?
Dan
antonio.guirado
Level 3
Level 3
you should use a L2TP tunnel over your IPSEC connection to encapsulate L2 traffic.
hi,
How can i modify my vpn to use L2TP?
sorry I am still learning this.
thanks.
