small SOHO91 router, hub interface
mlopacinski
Hello
I use SOHO91 router which has 4 "hub" ports and two routed ports (inside,outside). On of the "hub" ports is not working correclty. How can i check it's statistics ? For ethernet i have only ethernet0 and ethernet1 (LAN and internet connection). Show controllers did not reveal any usefull information. I would like to check collisions etc. for each "hub" port.
Thanx
paolo bevilacqua
by definition hub ports are not manageable, collision counters etc are shared across all ports. These are not switched ports.
I'm afraid that if one port doesn't work well you need to replace the router, or connect a switch downstream, that will give you a switched LAN.
