Smallest/least expensive OC3 capable router
jasommer
Can some one verify my findings? It appears that the 3825 is the smallest router (currently marketed/supported) capable of terminating an OC-3. Am I missing a router? Thanks
Danilo Dy
2691, 3600, and 3700 also supports OC3 but they are already EOS models.
Currently, only 3825 is the minimum model that supports OC3; NM-1A-OC3-POM, SFP-OC3-MM, SFP-OC3-IR1, and SFP-OC3-LR1.
http://www.cisco.com/en/US/products/ps5855/products_relevant_interfaces_and_modules.html
Note that these are ATM cards and sometime by 'OC-3' people means POS instead.
does that mean, a working OC3 connected to POS interface , will not work when connected on ATM OC3 card?
or it will work?
It will not work, as explained to you already in another thread.
