Smart License Not Authorized
n.oneill
We have configured our device to use Specific License Reservation (offline method) and reserved a performance license for this device, however, two other feature licenses show as NOT AUTHORIZED. How can I resolve this issue and what is causing these feature sets to be listed?
#sh license summary
Smart Licensing is ENABLED
License Reservation is ENABLED
Registration:
  Status: REGISTERED - SPECIFIC LICENSE RESERVATION
  Export-Controlled Functionality: ALLOWED
License Authorization:
  Status: NOT AUTHORIZED
License Usage:
  License                 Entitlement tag               Count Status
                          (ISR_4400_Application)            1 NOT AUTHORIZED
                          (ISR_4400_Security)               1 NOT AUTHORIZED
  ISR_4451_2G_Performance (ISR_4451_2G_Performance)         1 AUTHORIZED
balaji.bandi
Do you have License for Application and Security ? or is this right to use ?
NOT AUTHORIZED
The following enforcement mechanisms are available:
  • Hard enforcement: Hard enforcement is applicable only for enforced licenses (for example, Hsec or boost). When you do not authorize the required licenses by installing the auth-code, the license cannot be used, and the feature is disabled.
  • Soft enforcement: When you do not authorize the required licenses by installing the auth-code, you can continue to use the license. However, the system displays an appropriate syslog message and the license status is “Not Authorized”. However, you are not authorized to use these licenses without purchasing them.
BB
We only have the performance license and we are not using any feature of the security or application feature set that I can tell.
