SSH configuration in IOS version 15.0(1)M2
CSCO11866384
I configured the below in IOS ver 12.4(5a) is working fine (able login using Putty) , but the same configuration is not working in IOS ver 15.0(1)M2 (Not able to login using Putty)
hostname hostname
ip domain-name
domainname
crypto key generate rsa
ip ssh time-out 120
ip ssh authentication-retries 2
line vty 0 4
password
password
transport input all
Hello, what type of authentication do you use : local or aaa ? Maybe it is an AAA authentication problem, because the SSH configuration seems OK for me.
Youssef
P.S : try to connect from another terminal or from a router.
6 Replies 6
Youssef
Ur reply was very usefull. I tried from a router to that router. It is working.
then the problem identified in firewall settings.
j-mccarthy
try this
username admin password cisco123
line vty 0 4
login local
then login using admin, cisco123
for ssh you must use a username/password so  as previous poster said you must have a user on local database or on a tacacs+/radius server
and use login local command if username on local router.
Regards.
Alain.
CSCO11866384
Thanks All,
The problem was with firewall settings. The ssh protocol was blocked in my firewall.
You're welcome !!!
