08-09-2021 02:12 AM
hello, i cant ssh to my cisco 2900, it's keep showing connection timed out, but i if i connect via telnet it's works, here's my config
TLKM-CF-CM#sh ip ssh SSH Enabled - version 2.0 Authentication timeout: 120 secs; Authentication retries: 3 Minimum expected Diffie Hellman key size : 1024 bits IOS Keys in SECSH format(ssh-rsa, base64 encoded): ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgQC0PeDZUjcFLv2pO8oWuJT8tzAWkMR9Ka5c7j99lTj/ SOXXH1fS6ck3L1HRfJvmR1P9nr7DSS8gMAlvPGTSD2x+5vYJhAmR5Ifdje2NPIjvkI3j82FVuIN02Dss kesJShFBN+q97+etQrdf6GD8kO3x8Jfp3HjCntfDiH1EF+wnhw== hostname TLKM-CF-CM ! boot-start-marker boot-end-marker ! ! logging buffered 51200 warnings ! no aaa new-model ! ip cef ! ! ! ip flow-cache timeout inactive 600 ip domain name yourdomain.com no ipv6 cef multilink bundle-name authenticate line con 0 login local line aux 0 login local line 2 no activation-character no exec transport preferred none transport input all transport output pad telnet rlogin lapb-ta mop udptn v120 ssh stopbits 1 line vty 0 4 privilege level 15 login local transport input telnet ssh line vty 5 15 privilege level 15 login local transport input telnet ssh ! scheduler allocate 20000 1000 ! end
08-09-2021 03:21 AM - edited 08-09-2021 03:23 AM
Check any ACL applied on the interface which stopping to get in using port 22, what is the device from your are trying SSH to device ( PC or another router or switch ?)
=====️ Preenayamo Vasudevam ️=====
08-09-2021 05:15 AM
there's no acl applied, anyone in my WAN (PC/Router) can access my router via telnet but cant access via ssh. i asked my ISP provider, they said there's no blocking on port 22
08-09-2021 05:19 AM
This is from WAN side, how about from inside ? is the same case ?
we need to Look full config here please post " show run " from device having issue, and tell us what is your source IP address you are intiating SSH connection ? ( enable debug and check by intiating connecting and post the logs along with show run)
08-09-2021 02:17 PM
It is helpful to see the output of show ip ssh indicating that SSH is enabled (and limited to version 2, not version 1). Is it possible that your ssh client is attempting version 1?
It is interesting to see the partial configuration (and hope it is current and accurate). The vty ports are not using access class so that is not impacting ssh remote access. Both telnet and ssh are enabled so that is good.
It might be helpful to run debug for ssh (after changing the logging level for logging buffered to debug) and post any output when attempting ssh connection.
I am wondering if there might be some type of thing like control plane policing. To determine that we would need to see the complete configuration (masking any sensitive information like Public IP and passwords).
08-10-2021 12:05 AM
srry for not to mention it first that my router cant accessed via ssh from WAN, but it's works from LAN, i posted the sh run above
08-10-2021 12:02 AM
its works from LAN but not works from WAN, here's my sh run,
PC -> router -> WAN -> *router -> lan -> PC
*the router that i can't access via ssh
sh run Building configuration... Current configuration : 6313 bytes ! ! Last configuration change at 04:05:55 UTC Tue Aug 10 2021 by sistel version 15.2 service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname TLKM-CF-CM ! boot-start-marker boot-end-marker ! ! logging buffered 51200 warnings ! no aaa new-model ! ip cef ! ! ! ! ! ! ! ! ip flow-cache timeout inactive 600 ip domain name yourdomain.com no ipv6 cef multilink bundle-name authenticated ! ! ! crypto pki trustpoint TP-self-signed-1708665784 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-1708665784 revocation-check none rsakeypair TP-self-signed-1708665784 ! ! crypto pki certificate chain TP-self-signed-1708665784 license udi pid CISCO2901/K9 sn ******* license boot module c2900 technology-package datak9 ! ! username sistel privilege 15 password 7 ******* username telkom privilege 15 password 7 ******* username support privilege 7 password 7 ******* username tri privilege 15 secret 4 ******* ! redundancy ! ! ip ssh version 2 ! track 1 ip route 10.10.10.0 255.255.248.0 reachability delay down 120 up 120 ! track 2 ip sla 1 delay down 120 up 120 ! track 3 ip sla 2 delay down 120 up 120 ! class-map match-any Management match protocol dhcp match protocol dns match protocol kerberos match protocol ldap match protocol snmp match protocol socks match protocol syslog class-map match-any Transactional match protocol finger match protocol notes match protocol secure-telnet match protocol sqlserver match protocol telnet match protocol icmp match protocol xwindows match protocol ssh class-map match-any Voice class-map match-any Routing match protocol bgp match protocol eigrp match protocol ospf match protocol rip match protocol rsvp class-map match-any Signaling ! policy-map QoS-Policy-1 class Voice set dscp ef priority percent 30 class Signaling set dscp cs3 bandwidth percent 5 class Routing set dscp cs6 bandwidth percent 5 class Management set dscp cs2 bandwidth percent 5 class Transactional set dscp af21 bandwidth percent 5 class class-default fair-queue random-detect policy-map QoS-Policy-2 class class-default shape average 256000 service-policy QoS-Policy-1 ! csdb tcp synwait-time 30 csdb tcp idle-time 3600 csdb tcp finwait-time 5 csdb tcp reassembly max-memory 1024 csdb tcp reassembly max-queue-length 16 csdb udp idle-time 30 csdb icmp idle-time 10 csdb session max-session 65535 ! ! ! ! interface Loopback0 ip address 192.******* 255.255.255.255 ! interface Embedded-Service-Engine0/0 no ip address shutdown ! interface GigabitEthernet0/0 description WAN to PE bandwidth 1024 ip address 172.******* 255.255.255.252 ip nbar protocol-discovery ip flow ingress duplex auto speed auto ! interface GigabitEthernet0/1 description LAN DATA ip address 10.******* 255.255.240.0 ip policy route-map telkom standby 2 ip 10.******* standby 2 priority 200 standby 2 preempt standby 2 track 1 decrement 200 duplex auto speed auto ! interface GigabitEthernet0/0/0 description LAN VOICE no ip address ! interface GigabitEthernet0/0/1 no ip address shutdown ! interface GigabitEthernet0/0/2 no ip address shutdown ! interface GigabitEthernet0/0/3 no ip address shutdown ! interface Vlan1 description VLAN VOICE ip address 172.******* 255.255.255.224 ! ! router bgp 65260 bgp log-neighbor-changes neighbor 172.******* remote-as 17974 ! address-family ipv4 network 10.******* mask 255.255.240.0 network 172.******* mask 255.255.255.224 network 172.******* mask 255.255.255.252 network 192.******* mask 255.255.255.255 redistribute connected neighbor 172.******* activate neighbor 172.******* soft-reconfiguration inbound exit-address-family ! ip forward-protocol nd ! no ip http server no ip http secure-server ip flow-export source GigabitEthernet0/0 ip flow-export version 9 ip flow-export destination 10.10.4.251 9991 ! ip route 0.0.0.0 0.0.0.0 172.******* ip route 170.******* 255.255.255.252 10.******* name wan_icon ip route 170.******* 255.255.255.252 10.******* name wan_icon ! ip access-list extended icon permit ip 10.******* 0.0.15.255 any ip access-list extended telkom permit ip 10.******* 0.0.15.255 10.21.0.0 0.0.255.255 permit ip 10.******* 0.0.15.255 host 10.******* permit ip 10.*******0 0.0.15.255 10.******* 0.0.0.255 permit ip 10.******* 0.0.15.255 10.******* 0.0.0.255 ! ! ip prefix-list advertised seq 101 permit 10.*******/20 ip prefix-list advertised seq 102 permit 172.*******/27 ip prefix-list advertised seq 103 permit 192.*******/32 ip prefix-list advertised seq 104 permit 172.*******/30 ip prefix-list advertised seq 200 deny 0.0.0.0/0 le 32 ip sla auto discovery ip sla 1 icmp-echo 172.******* source-ip 172.******* ip sla schedule 1 life forever start-time now ip sla 2 icmp-echo 170.******* source-ip 10.******* ip sla schedule 2 life forever start-time now access-list 100 permit ip 10.******* 0.0.15.255 host 10.******* access-list 100 permit ip host 10.******* 10.******* 0.0.15.255 ! route-map telkom permit 10 match ip address telkom set ip next-hop verify-availability 172.******* 1 track 2 set ip next-hop verify-availability 10.******* 2 track 3 ! route-map telkom permit 20 match ip address icon set ip next-hop verify-availability 10.******* 1 track 3 set ip next-hop verify-availability 172.******* 2 track 2 ! ! snmp-server community hubert RO snmp-server enable traps tty snmp-server enable traps entity-sensor threshold ! control-plane ! ! privilege exec level 7 traceroute ip privilege exec level 7 traceroute privilege exec level 7 ping ip privilege exec level 7 ping privilege exec level 7 clear ip accounting privilege exec level 7 clear ip privilege exec level 7 clear ! line con 0 login local line aux 0 login local line 2 no activation-character no exec transport preferred none transport input all transport output pad telnet rlogin lapb-ta mop udptn v120 ssh stopbits 1 line vty 0 4 privilege level 15 login local transport input telnet ssh line vty 5 15 privilege level 15 login local transport input telnet ssh ! scheduler allocate 20000 1000 ! end
08-10-2021 12:30 AM
its works from LAN but not works from WAN, here's my sh run, PC -> router -> WAN -> *router -> lan -> PC *the router that i can't access via ssh
Is this LAB or real deployment ?
Since you confirmed LAN side working SSH, i do not see any issue around SSH config here for now.
what IP address from PC (left side) try to SSH? (outside IP address ?)
Do you see on the PC connected Router (have not ACL for SSH ?) is the traffic for SSH leaving the Router,
worth enable debug on both Routers to understand the issue. (and initiate the connection and post the debug Logs ?)
08-10-2021 08:04 AM
I want to be sure that my understanding of this situation is correct. The PC on left in the diagram is the source of telnet and ssh. telnet or ssh from that PC goes through a router and over a WAN to reach the router which is the destination for telnet and ssh. From the left PC telnet to the router is successful but ssh from the left PC to the router fails. ssh from the lan on the right is successful. The PC on the left is able to ssh to other devices. If any of this is not correct please clarify.
I see these points:
- ssh from the local lan works and this shows that ssh is correctly set up on the router.
- telnet from the PC on the left works and that demonstrates that routing and IP connectivity are correct and working.
- the running config shows that there is no access list on the outside interface and no access class on the vty so there is no security policy on the router that would impact ssh.
- the class map treats telnet and ssh the same so it would have no impact on ssh.
- the running config does restrict ssh to version 2. I have suggested the possibility that the PC attempting ssh might be using version 1. This should be investigated.
- every thing that we see looks like ssh should work. But ssh does not work. So there must be something that we do not see that is impacting ssh.
I suggest these steps for investigating the issue:
- change logging buffered from level warning to level debug.
- attempt ssh from the PC on the left.
- post all debug output.
If the issue is that the PC is using ssh version 1 the debug output should show this. I am guessing that there might be no debug output. This would indicate that the ssh request did not get to the router and that the issue is that something along the path (perhaps the router on the left or something in the WAN) is dropping the ssh.
08-09-2021 03:03 PM
Hello
Try removing the current crypto key and generate a new one, then test again.
conf t
crypto key zeroize
crypto key generate rsa label local-key general-keys modulus 2048
ip ssh ver 2
08-10-2021 12:06 AM
srry i forgot to mention that my router cant accessed via ssh from WAN, but it's works if i ssh from LAN, i posted the sh run above
