SSH from a Router
Amin Shaikh
Can i do SSH from a router session
[ I am connected to a router and needs to have an ssh session with firewall can I do it or need to have an SSH client installed on my desktop ]
9 Replies 9
spremkumar
Level 9
Level 9
AFAIK I dont think its possible to establish a SSH session from a router ...
regds
you need that your router works like an SSH client? Sure it's possible:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hsec_c/part25/ch10/h_ssh2.htm#wp1061462
The Cisco router is like a Unix box ;)
Andrea
Edwin
It may be a version (or feature set) dependent thing. But it is certainly possible to establish a SSH session from an IOS router to some other device. I have done it many times and it works just fine.
Rick
Rick
Edison Ortiz
Yes, but you need the K9 feature set for the SSH client on the source router.
Yes that is true. Any SSH (client or server) requires the K9 feature set. So it makes it at least feature set dependent. And on some older versions of code it is not supported.
Rick
Rick
Rick,
I wasn't correcting you. I was replying to the OP.
Sorry for any misunderstanding.
Edison
No problem. And I am not sure that there is any misunderstanding. You added a significant clarification that K9 (crypto image) is required for SSH. My response affirms that you are correct and changes my earlier statement that it MAY BE feature set dependent to it IS feature set dependent.
It adds a lot of value to the forum to have multiple people responding, each with their own perspective and their own piece of information to add. I value having you as a contributor and hope that you will continue to be active in the forum.
Rick
Rick
Rick,
Glad we are clear - my sentiments exactly on everything you said :)
Thanks to all.
YES it works...
