SSH is not working in Ubuntu /Windows CMD prompt
Cisconew
I am able to SSH my Router (Physical Device/1841) via Putty terminal.
But not able do it through Ubuntu terminal/Windows CMD prompt.
Please find below Show SSH output for reference.
Router-1841#sh ssh
Connection Version Mode Encryption Hmac State Username
0 2.0 IN aes256-cbc hmac-sha1 Session started jason
0 2.0 OUT aes256-cbc hmac-sha1 Session started jason
%No SSHv1 server connections running.
Also, please find below the ssh output from ubuntu terminal.
$ ssh username@192.168.1.100
Unable to negotiate with 192.168.1.100 port 22: no matching key exchange method found. Their offer: diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
Any suggestion?
Thanks in advance.
I have added the below to the config file along with one you have given.
Ciphers aes256-cbc,aes128-ctr,aes192-ctr,aes256-ctr,aes128-cbc,3des-cbc
Now it is working. Thanks
how did you configure the SSH client ? You need to include the DH sha1 in the configuration file of your client. Post the content of the client configuration file...
Please find below the ubuntu ssh config file:
$ cat /etc/ssh/ssh_config
# This is the ssh client system-wide configuration file. See
# ssh_config(5) for more information. This file provides defaults for
# users, and the values can be changed in per-user configuration files
# or on the command line.
# Configuration data is parsed as follows:
# 1. command line options
# 2. user-specific file
# 3. system-wide file
# Any configuration value is only changed the first time it is set.
# Thus, host-specific definitions should be at the beginning of the
# configuration file, and defaults at the end.
# Site-wide defaults for some commonly used options. For a comprehensive
# list of available options, their meanings and defaults, please see the
# ssh_config(5) man page.
Include /etc/ssh/ssh_config.d/*.conf
Host *
# ForwardAgent no
# ForwardX11 no
# ForwardX11Trusted yes
# PasswordAuthentication yes
# HostbasedAuthentication no
# GSSAPIAuthentication no
# GSSAPIDelegateCredentials no
# GSSAPIKeyExchange no
# GSSAPITrustDNS no
# BatchMode no
# CheckHostIP yes
# AddressFamily any
# ConnectTimeout 0
# StrictHostKeyChecking ask
# IdentityFile ~/.ssh/id_rsa
# IdentityFile ~/.ssh/id_dsa
# IdentityFile ~/.ssh/id_ecdsa
# IdentityFile ~/.ssh/id_ed25519
# Port 22
# Ciphers aes128-ctr,aes192-ctr,aes256-ctr,aes128-cbc,3des-cbc
# MACs hmac-md5,hmac-sha1,umac-64@openssh.com
# EscapeChar ~
# Tunnel no
# TunnelDevice any:any
# PermitLocalCommand no
# VisualHostKey no
# ProxyCommand ssh -q -W %h:%p gateway.example.com
# RekeyLimit 1G 1h
SendEnv LANG LC_*
HashKnownHosts yes
GSSAPIAuthentication yes
you need to add the line below to your SSH config file:
KexAlgorithms +diffie-hellman-group1-sha1
