New 4331 very slow and intermittent internet
Jkad432
Hello all,
 replaced a 2900 router with a new 4331 isr. Worked great for 5 days and then Became increasingly unresponsive. Reset to factory and started from scratch again and it works (local network works great) seeing some packet loss pinging external ip from an external network and it’s very slow loading web pages, I currently have the trial boost license. I have gotten the notice that I was approaching the license cap one time. Negotiation is set to auto.
any ideas what would be causing such slow speeds
18 Replies 18
what is the throughput level ?
4331#sh platform hardware throughput level
balaji.bandi
We need some more information  to identify :
1. what kind of abdn width you have
2. can you post the 4331 config (post show version / show running config / show license ?)
3. when it was 2900 is that worked as expected ?
what you see any logs ?
BB
Jkad432
Throughput is 300000
2900 started being unresponsive about two weeks ago
i will be in the office shortly and will post the other information
throughput should be 'level boost' if the license works correctly...where boost means unlimited...
as per the description looks like you have throughput license issue .
but that can only confirmed once we have configuration other information as i rquested on other poist.
BB
sh version
Cisco IOS XE Software, Version 16.06.04
Cisco IOS Software [Everest], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.6.4, RELEASE SOFTWARE (fc3)
config is attached
Jkad432
sh license
Index 1 Feature: appxk9
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Active, Not in Use, EULA not accepted
        License Count: Non-Counted
        License Priority: None
Index 2 Feature: uck9
Index 3 Feature: securityk9
Index 4 Feature: ipbasek9
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
Index 5 Feature: FoundationSuiteK9
Index 6 Feature: AdvUCSuiteK9
Index 7 Feature: cme-srst
        License Count: 0/0  (In-use/Violation)
Index 8 Feature: hseck9
Index 9 Feature: throughput
        Period left: 7  weeks 4  days
        Period Used: 6  days 18 hours
        License Priority: Low
Index 10 Feature: internal_service
sh version
set the throughput level to 'boost':
4331(config)#platform hardware throughput level boost
and reboot the device.
doesn't work.
% Invalid input detected at '^' marker.
What are your options after:
platform hardware throughput level ?
100000 throughput in kbps
300000 throughput in kbps
Also seeing packet loss when pinging my external ip from outside the office
attached my run config if that helps
Jkad432
sh version
