05-02-2021 03:03 PM
Hi All,
The public IP address of the LTE cellular module is 1.145.38.99 (Australia), however, when running the command: show cellular 0/0/0, it shows the public IP address as being 22.165.47.87 (USA). Would this be impacting the ability to use SSH remotely?
05-02-2021 03:15 PM
Post the configuration, dd you allow SSH come in from ACL ? or ISP blocking either of the case.
what do you see in the Logs? ( show logg)
05-02-2021 04:13 PM
Hi Balaji,
Configuration is below. The router was configured by a network engineer in Pakistan and he has advised that it's all set up as it should be, so I'm unsure how to determine whether SSH is allowed to come in from the ACL.
The router is offline, so cannot access logs.
Current configuration : 2736 bytes ! ! Last configuration change at 20:54:24 UTC Sun May 2 2021 by william ! version 15.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname VT-STKN-RTR-0001 ! boot-start-marker boot-end-marker ! ! enable secret 5 <redacted for privacy> ! aaa new-model ! ! aaa authentication login default local aaa authorization exec default local ! ! ! ! ! aaa session-id common ! ! ! ! ! ! ! ! ! ! ! ! ip dhcp pool LOCAL network 10.10.20.0 255.255.255.0 default-router 10.10.20.1 dns-server 4.2.2.2 8.8.8.8 ! ip dhcp pool LAN network 10.10.10.0 255.255.255.0 default-router 10.10.10.1 dns-server 4.2.2.2 8.8.8.8 ! ! ! ip domain name vergetel ip cef no ipv6 cef multilink bundle-name authenticated ! chat-script lte "" "AT!CALL" TIMEOUT 60 "OK" cts logging verbose ! ! license udi pid CISCO1921/K9 sn FGL1923213X ! ! username tempadmin privilege 15 <redacted for privacy> username william password 0 <redacted for privacy> ! redundancy ! ! controller Cellular 0/0 lte modem link-recovery rssi onset-threshold -110 lte modem link-recovery monitor-timer 20 lte modem link-recovery wait-timer 10 lte modem link-recovery debounce-count 6 ! controller VDSL 0/1/0 ! ! ! ! ! interface Embedded-Service-Engine0/0 no ip address shutdown ! interface GigabitEthernet0/0 ip address 10.10.20.1 255.255.255.0 ip nat inside ip virtual-reassembly in duplex auto speed auto ! interface GigabitEthernet0/1 ip address 10.10.10.1 255.255.255.248 ip nat inside ip virtual-reassembly in duplex auto speed auto ! interface ATM0/1/0 no ip address shutdown no atm ilmi-keepalive ! interface Ethernet0/1/0 no ip address shutdown ! interface Cellular0/0/0 no ip address ip nat outside encapsulation slip dialer in-band dialer pool-member 1 ! interface Dialer0 ip address negotiated ip nat outside ip virtual-reassembly in encapsulation slip dialer pool 1 dialer idle-timeout 0 dialer string lte dialer persistent ! ip forward-protocol nd ! ip http server ip http authentication local ip http secure-server ! ip nat inside source list Internet interface Dialer0 overload ip route 0.0.0.0 0.0.0.0 Dialer0 ! ip access-list extended Internet permit ip 10.10.20.0 0.0.0.255 any permit ip 10.10.10.0 0.0.0.255 any ! ! ! ! ! ! control-plane ! ! ! line con 0 line aux 0 line 2 no activation-character no exec transport preferred none transport output pad telnet rlogin lapb-ta mop udptn v120 ssh stopbits 1 line 0/0/0 script dialer lte no exec rxspeed 100000000 txspeed 50000000 line vty 0 4 password <redacted for privacy> transport input telnet ssh line vty 5 15 password <redacted for privacy> transport input telnet ssh ! scheduler allocate 20000 1000 ! end
05-02-2021 04:20 PM
high level I do not see any SSH config - but you can try telnet into the router using public IP address and let us know if that works?
follow the below guide to configure SSH :
https://www.cisco.com/c/en/us/support/docs/security-vpn/secure-shell-ssh/4145-ssh.html
05-03-2021 10:50 AM
William
I agree with @balaji.bandi that it is difficult to tell from the config what is the state of SSH. Can you get to the switch and execute the command show ip ssh? Its output would verify whether SSH is active.
I do not see anything in the config that would prevent SSH access. Are we correct in assuming that SSH does not work? If SSH does not work then I agree that attempting access using telnet would be a good test.
I do not think it relates to your possible issue with SSH but I do notice an inconsistency in your config. Your DHCP pool specifies this
but the interface where that subnet is configured uses mask of 255.255.255.248.
05-03-2021 03:22 PM - edited 05-03-2021 03:22 PM
Hi Rick
SSH config below.
VT-STKN-RTR-0001>show ip ssh SSH Enabled - version 1.99 Authentication methods:publickey,keyboard-interactive,password Authentication timeout: 120 secs; Authentication retries: 3 Minimum expected Diffie Hellman key size : 1024 bits IOS Keys in SECSH format(ssh-rsa, base64 encoded): ssh-rsa <redacted for privacy>
The Dialer0 interface is showing a public IP address in the USA (22.166.248.36) when the actual public IP address of the LTE cellular service is in Australia (1.129.108.144). I presume this would be causing an issue as I can load up the web UI login for 22.166.248.36 when I'm on the same network as the router, however, when it comes to WAN, it cannot be accessed from this address, nor the Australian IP. Very strange.
Any assistance would be great. Thanks.
05-04-2021 02:00 AM
Thanks for the information, regarding the IP address you need to be in touch with your ISP, nothing we can do about it.
Thank you for the information, you have SSH running, Can you please confirm from Local Lan are you able to SSH and Telenet to the device ?
Als have you tested from outisde Telnet ? or SSH ? what you see the Logs (enable Debug when you trying SSH from outside, ) as i presume it is not even reaching the router your request.
05-04-2021 07:52 AM
William
Thanks for the additional information. The output does confirm that SSH is configured and activated, which eliminates one potential cause of the problem. I have a few more questions:
- can you confirm that devices connected to your inside networks are successful in accessing resources on the Internet?
- can you confirm that devices connected to your inside networks are successful in SSH to the router?
- when you attempt SSH from outside do you get any type of response? Or does the SSH request just hang and time out?
- just to be sure that it is not something specific to SSH can you attempt telnet to the router from a device in the Internet?
- can you ping or traceroute to the router outside interface from devices in the Internet? (try both of the identified addresses)
- I agree with @balaji.bandi that it sounds like the SSH request may not be getting to the router. Is it possible to run debug ip ssh, attempt SSH from the Internet, and look for any debug output?
- I am wondering about the configuration for line 0/0/0 that specifies no exec. As a test could you remove that line and test SSH again?
I find this observation interesting "when it comes to WAN, it cannot be accessed from this address, nor the Australian IP". I am not clear why 2 IP addresses are indicated but I am not convinced that the IP address is the real issue with SSH. If the address were the cause of the problem I would expect that one or the other would work. If you access something in the Internet from a device on your inside network and then show the translate table on the router would it shed light on which address is being used?
