Stack ports are down at 9300
Leftz
Level 4
Level 4
Hi we have stack switch 9300. Now we notice stack ports are down. and did not see any lights abnormal. I think this might be caused by connection loose. Do you think anything else can cause the issue? Does the stack port has light which shows the port status down or up? Thank you
2 Accepted Solutions
Try fixing the stack cable, you should be ok.
BB
Leo Laohoo
That stack is not cabled up properly.
I would recommend organizing an outage and re-cabling the stack according to best-practice standards.
balaji.bandi
yes as per the output, Looks like cable issue, take the configuration backup out of the box in the maintenance window, try to re-insert the cable check intact and check with show command again.
by the way what IOS XE code running?
Note : as per the put you have 4 switches, is the 4th switch ok ?
Also refer the stacking documenation make sure all in correct :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/hardware/install/b_c9300_hig/b_c9300_hig_chapter_010.html
BB
Thank you balaji for your reply.
Yes, we have four switches as one stack working well running 17.3.3
BB
Leo Laohoo
