Stack WS-2960S-48-FPS
Hi.
I am installing a’ stack with 3st WS-2960S-48FPS with IOS c2960s-universalk9-tar.150-1.SE2bin.
I am planning of using Auto-upgrade, and have installed flash:c2960s-universalk9-tar.150-1.SE2.tar on my master switch. But when reloading my stack who should upgrade switch2+3 from IOS c2960s-universalk9-mz.122-55.SE3 to c2960s-universalk9-tar.150-1.SE2bin.
I get an error in my log:
Mar 1 01:06:29.939 CET: %IMAGEMGR-6-AUTO_DOWNLOAD_SW_INITIATED: Auto-download-software process initiated for switch number(s) 3
*Mar 1 01:06:29.939 CET: %IMAGEMGR-6-AUTO_DOWNLOAD_SW:
*Mar 1 01:06:29.939 CET: %IMAGEMGR-6-AUTO_DOWNLOAD_SW: Upgrading system(s) 3
*Mar 1 01:06:29.939 CET: %IMAGEMGR-6-AUTO_DOWNLOAD_SW: Unable to create temp dir "flash:update"
Boot config on master switch:
Switch1: (master)
BOOT path-list     : flash:c2960s-universalk9-mz.150-1.SE2.bin
Config file         : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break       : no
Manual Boot         : no
HELPER path-list   :
Auto upgrade       : yes
Auto upgrade path   : flash:c2960s-universalk9-tar.150-1.SE2.tar
There is no problem witch space on flash
//Johan
paolo bevilacqua
If automaic fails, session from master to members, unpdate manually then reload all switches at a same time.
