Static IP Mapping for Cisco 891 Router
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-23-2011 10:59 AM - edited 03-04-2019 12:48 PM
Hello
Does anyone know if the Cisco 891 does Static IP mapping and where I can get instructions how to use Static IP Mapping?
Is the Static IP Mapping done throught CLI or through the CCP?
- Labels:
Other Routers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-23-2011 11:29 AM
Do you mean "static nat" or "static ip address and mac-address" or something else? Please explain a bit more about your question.
Toshi
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-23-2011 05:24 PM
I want to assign a static ip address to a server,a laptop.
On the WRV S4400N I was able to do this through the GUI and I had just need to enter the Static IP,Mac Address,Host name.
Can this be done on the Cisco 891 router and how would this be done?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-24-2011 12:29 AM
this is called a DHCP manual binding and it can be done this way:
1) create a parent DHCP pool for dynamic leases
-exclude all real static addresses: ip dhcp excluded x.x.x.x y.y.y.y where x.x.x.x is starting IP and y.y.y.y is ending IP
you can use multiple command like this one and you can only use one IP if you will
ip dhcp pool MYPOOL
network 192.168.1.0 /24
default-router 192.168.1.254 this is an excluded address
dns-server 192.168.1.253 same as above
domain-name xxxxx
lease x x x
2) create the child pool for the manual binding one child pool per host
ip dhcp pool MYHOST
host 192.168.1.5 /24
client-identifier 01XX.XXXX.XXXX.XX where XXXXXXXXXXXX is the MAC address of the host
or
hardware-address XXXX.XXXX.XXXX
To know if you need client-id or hw-address just let your host get a dynamic IP from parent pool and then issue show ip dhcp binding command to see if it uses client-id or hw-address
then release IP on host enter correct command in child pool and renew IP on host.
Regards.
Alain.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-28-2011 10:11 PM
You could use the Cisco Configuration Professional GUI to configure dhcp pool and static binding as well. Navigate to
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-25-2012 10:58 AM
Using the CCP
I went to the DHCP Pools and I have one there already named ccp-pool1, Interface is Vlan1
in the DHCP pool Range value is 192.168.2.175-192.168.2.254
I presume DHCP Pool Range is the IP that the client are being issued.
Now I went to the DHCP bindings under the DHCP.
there are 3 fields Name,Host IP address, Mask
for these fields what name should I use, for the Host IP is this the static IP I want to issue from the pool Range above, I can pick for example 192.168.2.176 if its avaviable to use. For the Mask is that the subnet that I am using which is 255.255.255.0
For the Identifier drop down box do I select Hardware Address since I am going to use the Mac address of the host.
For type do I select Ethernet. After that I click on Ok, will the router needed to be rebooted to reflect the changes added.
In the Utilites do I need to write the Startup Configuration.
