Static NAT entire subnet(s) to one public IP
Dennis Topo Jr
I ran into a situation where one interface on an ASA was linked to another partners router via a public IP in order to service a web portal application. The LAN side interface of the ASA is connected to a private address space, and the entire address space was static natted to the one public interface IP connected to the partner network. This is how it was set up. I assume there was a reason to do it this way, and not PAT the public interface as is most times the case.
In other words  192.168.0.0 /16 ---->>>Static NAT--->>2.2.2.2(ASA-public) ----->2.2.2.1(next-hop router) ---->>>routed to----->>>3.3.3.3 (portal app)
Is it safe to assume that only one private IP connection at a time would be able to access the portal? Because I attempted connections from 2 machines on the private side, and was able to access to portal login page. Also ran simultaneous continues pings to the portal IP..... and no issues. It was translating both. I had always assumed this would not work, and you would need to PAT for this. ......????
Any clarification or sharing of similar experiences is appreciated ..... Dennis
Jon Marshall
Dennis
Can you post the actual NAT configuration ?
Jon
Jon....Here's the NAT config.... pretty simple. Just looking for more of a confirmation on the static natting behavior
nat (inside,outside) source static TSF-LAN TSF-LAN destination static Apptrix Apptrix description ***VPN NAT Bypass Rule***
nat (inside,outside) source static TSF-LAN TSF-LAN destination static TST-LAN TST-LAN description ***VPN NAT Bypass Rule***
nat (inside,outside) source static SMTP-Server-I SMTP-Server-E description ***Mail Server NAT***
nat (inside,airbus) source static TSF-LAN interface - existing- specific to site LAN IPs
nat (inside,airbus) source static TSF-Remote interface -existing- specific to VPN IP pool
nat (inside,airbus) source static MPLS-10x interface description MPLS 10x NAT to Airbus   - added to NAT rest of network
nat (inside,airbus) source static MPLS-172.16x interface description MPLS 172.16x NAT to Airbus  - added to NAT rest of network
nat (inside,airbus) source static MPLS-192.168x interface description MPLS 192.168x NAT to  Airbus - added to NAT rest of network
nat (inside,outside) source dynamic TSF-LAN interface description ***Data LAN PAT Rule***
nat (guest,outside) source dynamic guest-net guest-pat description ***Guest LAN PAT Rule***
