Static NAT through FW
majed.balsharaf
HI all,
  I am having one DSL link and internet is working in it. I need to do static natting with my internal IP. 10.100.2.25/24
Please check the diagram of it:
5 Replies 5
John Blakley
You didn't state what type of router you had, so I'm going to give you an example for, say, a 2800.
Assuming that you're not natting at all on the FW (from the diagram you shouldn't be), you can do something like the following on the dsl router:
ip nat inside source static 10.100.2.25 188.53.62.x
int dialer0
ip nat out
int fa0/0
ip nat in
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Thanks for your reply brother.
  I am having 1841 series router. And I want to configure my static nat at Firewall. My firewall is cisco 5520
which firwall ver you r using.8.2 or 8.4
I am using 8.2
static (inside,outside) 192.168.201.12 10.1.1.3 netmask 255.255.255.255
This command maps an inside IP address (10.1.1.3) to an outside IP address (192.168.201.12).
Jawad
