static nat
leungcm
we would like to setup static NAT. detail please refer attached file. we get the ip segment is foloiwng:
210.5.10.128 - 210.5.10.158
we set the NAT to inner segment (172.16.x.x).
router A
ip route 210.5.10.129 255.255.255.255 210.5.10.157
router B
ip nat outside source static 172.16.1.33 210.5.10.129
ip nat outside source static 172.16.1.36 210.5.10.130
interface GigabitEthernet0/0
ip nat outside
interface GigabitEthernet0/2
ip nat inside
however, it does not work, any missing? please advise
royalblues
Level 10
Level 10
I think the statements have been reversed here..
If G0/0 is the interface connecting to routerA, then your NAT statements should look like
ip nat inside source static 172.16.1.33 210.5.10.129
ip nat inside source static 172.16.1.36 210.5.10.130
or
ip nat outside source static 210.5.10.129 172.16.1.33
Try this out and let us know
HTH, rate if it does
Narayan
