static routing for http(s) traffic
willemvwyk
I have the following setup:
LAN1 with DHCP server 10.20.30.253 & Internet server as gateway for LAN with IP 10.20.30.254. Both are on the same subnet.
I have a remote site LAN2 which is getting DHCP from LAN1. That is working fine. However I need to route all http & https traffic from LAN2 to LAN1's .254 server.
Currently my router at LAN2 has gateway of last resort 0.0.0.0 0.0.0.0 LAN1
How can I make this router at LAN2 route all http & https only traffic route back to the http server (.254)?
TIA
paolo bevilacqua
That is called PBR, if you search in the scrollbox you can get to the configuration guide or examples.
I am not sure if PBR will work as the WAN is on a /30 IP Range?
Another thought, can I build IP-IP tunnels between the sites and route these tunnels to the main site?
