Mutual Redistribution between EIGRP and BGP
dtran
Level 6
Level 6
Hi all, hope everyone is doing well !!!
I've got a topology below and mutual route redistribution is needed on the N9504 but I do not want EIGRP routes coming from the Cisco 4431 get redistributed into BGP. what's the best method to accomplish this ? and what's the AD value that the NGFW will see in its forwarding table for EIGRP redistributed routes ?
Thanks all in advance !!! I appreciate any inputs / suggestions !!!
Danny
When you redistributes EIGRP routes into BGP you would attach a route-map referencing usually a prefix-list to specify routes you want to redistribute thats EIGRP
Example:
router bgp 65001
redistribute eigrp 1 route-map ROUTES
route-map ROUTES permit 10
match ip address prefix-list EIGRP_ROUTES
ip prefix-list EIGRP_ROUTES permit x.x.x.x/x  <------ add as many prefix list statements as needed for the EIGRP routes you want
-David
Ruben Cocheno
@dtran
Note that your redistribution will affect your Routing domain including the SD-WAN part of the network.
You will need to match the source-protocol eigrp while redistributing it back to you Firewall
route-map eigrp-to-bgp
permit 10 match ip address prefix-list eigrp-mpls
ip prefix-list eigrp-mpls permit x.x.x.x/x <-- add all routes from EIGRP from mpls that you want to filter
route-map stop-eigrp 10 deny
match source-protocol eigrp 100
route-map stop-eigrp 20 permit
router eigrp 100
redistribute bgp 1000 metric 100 1 255 1 1500
router bgp 1000 bgp log-neighbor-changes
redistribute eigrp 100 route-map eigrp-to-bgp
neighbor 192.168.1.1 route-map stop-eigrp out
AD for those EIGRP redistributed routes will be 20
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
dtran
Level 6
Level 6
Thanks David and Ruben for your inputs !!! I very much appreciate it !!!
My end goal is to redistribute all EIGRP routes from the N7706 and only certain routes from Cisco 4431 MPLS router. I think I can use route-map / prefix-list for this.
As for BGP into EIGRP ... I only want certain BGP routes get redistributed to the Cisco 4431 MPLS router. Is that possible?
Thank you very much !!
Danny
If you dont use redistrubte between eigrp and bgp then it will be separate' totally separate.
Where the prefix learn from ebgp will only advertise via ibgp to FW and it AD will be 200 (since it learn via ibgp)
The prefix learn from eigrp will advertise to N7706 via also same igp eigrp.
So no need redistrubte.
The only point here is that for ibgp you need to use next-hop self otherwise you need to redistrubte ebgp interface ip connect to sdwan to the FW.
MHM
