Straight-Through or Crossover for Port Channels
Patrick Harrold
Hi All,
In everything I've read, there shoudl be a crossover when connecting two switches. However, at my company we use straight-throughs when connecting our core switch to our distribution switches. The distro is a 2960G (or S), and the core uses a X6748 module in a 6500 chassis. We use EtherChannel between the two as well.
I thought this worked because of auto-MDIX, but that is showing disabled on both sides of the cable.
2960G output - (Auto-MDIX                             :  Off   )
The 6500 has a static speed and duplex setting so I believe that disables auto-MDIX (per this, "if you specify either the speed or duplex setting MDI-X is lost.") (Located here: http://www.gossamer-threads.com/lists/cisco/nsp/85412)
So, can anyone tell me why this works?
14 Replies 14
cadet alain
I don't know this module but if it is a layer 3 module you need a straight-through cable if auto MDI/MDI-X is off and that could explain why it is working with this cable.
Alain
I believe it should be considered a layer 2 module per this:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_bulletin0900aecd800f6e27.html
So, it's a switch. Though Cisco calls it, "multilayer." Could just be marketing mumbo-jumbo referring to layer 1 and layer 2.
Patrick
Are the etherchannels from the 2960s to the 6500s L2 or L3 etherchannels ie. where is the inter vlan routing done ?
Jon
They are trunk etherchannels, so they have L2 VLAN tagged frames.
The inter-VLAN routing is done at our router: a different module in the 6500 chassis. We have a SUP720.
Thanks for the help guys.
Patrick
Are you absolutely sure about the cables being used ?
The 6500 is a very capable switch but i still can't see how this is working.
BTW multilayer switch generally just means it can switch packets at L2 and L3 ie. the L3 part is done in hardware so it is called L3 switching.
Jon
I'm 100% sure they are straight-through. We have a bunch of 2960's (G & S), all doing the same trunk back to the core over straight-through cables. Some are 2 interface bundles, some are 4.
I don't understand why either, even after a ton of reading. Hence, the post here
There's one way of finding out:  Run a TDR from the 2960G/S.
I have no idea why network admin blindly disable MDI/MDI-X.  This feature is every network admin's best friend.
I already checked the 2960G with this command:
show controllers ethernet-controller GigabitEthernet 0/24 phy det
And got this output (partial, obviously)
Auto-MDIX                             :  Off   [AdminState=1   Flags=0x000104C8]
The main network admin keeps auto-mdix disabled when he sets speed to static. He prefers for an interface to completely go down instead of auto-negotiating to 10 or 100Mbps. Gigabit or nothing. I don't really disagree with that outlook, but lets not get sidetracked
Speed is set to static (as is duplex) on the side of the X6748 blade as well, so I am assuming that auto-MDIX is off. The above command that I used for the 2960G cannot be used on the X6748.
Don't assume.  Run a TDR.  The result will show you the wire map.  It will give you a guarantee which pair goes to where.
Do not run the TDR on the 6500 because this will take FOREVER to finish.
It's straight-through. Here are the TDR results:
Interface Speed Local pair Pair length        Remote pair Pair status
Gi0/24    1000M Pair A     8    +/- 10 meters Pair A      Normal
                Pair B     8    +/- 10 meters Pair B      Normal
                Pair C     8    +/- 10 meters Pair C      Normal
                Pair D     8    +/- 10 meters Pair D      Normal
Patrick
Can you post the config of a port channel plus the member ports between a 2960 and the 6500 ?
Jon
2960G
interface GigabitEthernet0/24
description REMOVED
switchport mode trunk
logging event link-status
media-type rj45
speed 1000
duplex full
channel-group 2 mode desirable
interface Port-channel2
description REMOVED
speed 1000
duplex full
no keepalive
6500
interface GigabitEthernet2/35
description REMOVED
switchport
mtu 9000
speed 1000
duplex full
channel-group 203 mode desirable
interface Port-channel23
description REMOVED
switchport
mtu 9000
speed 1000
duplex full
no keepalive
abpsoft
Because it's 1000Base-T?
While it's not exactly been mandated by 802.3-whatever, the principle of operation of 1000Base-T made it trivial to support both crossover and straight cables (remember that it's no longer one twisted pair for TX and one for RX, but all four TPs are working in parallel and doing echo-compensated TX and RX at the same time). Actually, any permutation of rewiring the four twisted pairs would have been supportable, but AFAIK not all are typically implemented (ISTR 802.3 only speaks about one specific crossover scheme, but I don't remember if it was 4/5 and 7/8 straight or crossed as well). This is not exactly the same thing as Auto-MDI-X, which usually just cycles the 10Base-T/100Base-TX PHYs through two settings until link pulses are detected (note that Auto-MDI-X for 10/100 was standardized way later than 1000Base-T), so the CLI may not denote it as Auto-MDI-X being used. But that's cosmetic.
HTH,
Andre.
So, what you're saying is, it works for some reason, and that reason may or may not be auto-MDIX.
But that doesn't really answer why it works. I know you're saying it would be easy for them to support any mixing and matching of pairs, and just "re-wire" it corectly on the NIC side of one of the devices, but that just begs even more questions. What hardware is actually doing this? Is it standardized or documented somewhere?
Probably most importantly: is there some other name out there besides auto-MDIX that I should look for to ready up on?
Note: I don't want to be hand-fed the answer, I'd just like to at least be pointed in the right direction so I know exactly what is going on under the covers.
