Strange EIGRP/GRE issue
saimbt
I have 2 3825 routers and have configured GRE+ EIGRP. I have 2 tunnels one going to loctnA and the other to loctnB. The GRE tunnel to loctnA is pefect. There is a lot of latency on the loctnB GRE tunnel. The end to end ping to the physical interace results in a avg latency of 4 msec, whereas ping to the tunnel interface reseults on 110 msec.
Any leads?
-Sai.
5 Replies 5
guruprasadr
Level 7
Level 7
HI Sai, [Pls Rate if HELPS]
What is the "Tunnel Mode" configured on the Tunnel Interface.
If Tunnel Mode as "ipip" is configured means, remove the same and try. I have experienced the smiliar issue and after doing a same it worked properly.
Also, redo the configuration of EIGRP on either side for Location B. This will something look like a propability try but have experienced several such cases with EIGRP and after redo of config it has worked.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
Hi Guru,
everyting is default there is no ipip configured.
Edison Ortiz
Please post the relevant portion of the config.
__
Edison.
Tunnel1 is having the issue.
interface Tunnel0
bandwidth 6000
ip address 10.254.82.70 255.255.255.252
ip mtu 1420
ip tcp adjust-mss 1380
load-interval 30
delay 1
keepalive 10 3
tunnel source 10.254.82.126
tunnel destination 10.254.82.66
interface Tunnel1
bandwidth 6000
ip address 10.254.83.1 255.255.255.252
load-interval 30
delay 1
qos pre-classify
keepalive 10 3
tunnel source 10.254.82.58
tunnel destination 10.254.82.57
interface FastEthernet1/0
ip address 10.254.82.126 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting output-packets
ip flow ingress
ip flow egress
ip route-cache flow
no ip mroute-cache
load-interval 30
duplex full
speed 100
no cdp enable
interface FastEthernet1/1
bandwidth 6000
ip address 10.254.82.58 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
delay 1
duplex full
speed 100
no cdp enable
router eigrp
redistribute static
network 10.30.1.0 0.0.0.255
network 10.254.82.60 0.0.0.3
network 10.254.82.68 0.0.0.3
network 10.254.83.0 0.0.0.3
no auto-summary
router bgp
no synchronization
bgp log-neighbor-changes
neighbor 10.254.82.125 remote-as
no auto-summary
ip classless
ip route 10.30.0.0 255.255.0.0 10.30.1.254
ip route 10.108.32.0 255.255.240.0 10.30.1.254
ip route 10.254.32.176 255.255.255.240 10.30.1.254
ip route 172.21.167.0 255.255.255.0 10.30.1.254
MTU mismatch may cause the issue since it will cause many more traffic fragmentations.
I saw you have "ip mtu 1420" setup in Tunnel0 why not in Tunnel1? Any history reason?
I would suggest to configure same in Tunnel1 and give it try.
Or, use 'tunnel path-mtu-discovery' in Tunnel1 for its to do automatically detect proper MTU for end-2-end trffic flow.
Please let me know the result and rate it.
