Strange Problem Witth Asr1002 Fix RP1
Hi Dear Firend I set /32 Ip on loopback interface on ASR 1002 router
Router have not any Config ACL
but when ping ip address donnot reply to me
I change IOS version Upgrade modules By romon to version 16
But problem Still Exists
Pls Help Me
6 Replies 6
a few questions:
Where are you pinging from ? Can you ping the loopback locally, that is, when connected through the console ?
Post the config of your router...
I ping From console router CLI own Loopback Ip address
so how is your loopback reachable from the outside ? Do you announce the loopback address through a routing protocol, or static routing ?
I set /32 255.255.255.255 subnet  on loopback1
I ping from own router by console Connection
ping 192.168.1.1 source loopback1
hello
Just to confirm the below doesnt work, if so it must be a bug unless you have something netgaing it?
int lo1
ip address 192.168.1.1 255.255.255.255
no shut
ping 192.168.1.1 source loopback 1
Apply this and post out
access-list 100 permit ip host 192.168.1.1 any
access-list 100 permit ip any host 192.168.1.1
debug ip packet detail 100
debug ip icmp
ping 192.168.1.1 source loopback 1 repeat 1
res
Paul
Kind Regards
Paul
There has already been a request to post the router config. I would suggest that the output of these commands might help us to identify the issue
show ip interface brief
show ip route
Rick
Rick
