Stuck in rommon
johnross400
I somehow managed to mess up the flash file name and now I am trying to recover the 2600 router using the ROM monitor software procedure - I am stuck in rommon mode.
Has anyone tried this ??
I have attached some outputs...
Thanks for helping.
John
guruprasadr
Level 7
Level 7
Hi John, [Pls Rate if Helps]
This message indicates that the bootflash file system is corrupted, or the IOS files are invalid/corrupted.
Format to Specify:
rommon 16 > IP_ADDRESS=172.15.19.1
rommon 17 > IP_SUBNET_MASK=255.255.255.253
rommon 18 > DEFAULT_GATEWAY=172.15.19.2
rommon 19 > TFTP_SERVER=172.15.19.2
rommon 20 > TFTP_FILE=c2600-j1s3-mz.123-13a
rommon 21 > tftpdnld
INFO: Pls Note IP Address of TFTP Server & Default Gateway are same.Change accordingly. TFTP_FILE = Do not specify entire File Location (as in your output) & do not use the .bin extension during specification. Just specify the name of the File only in TFTP directory.
NOTE: All Variables are Case Sensitive. Don't Use Lower Case Format
IP_ADDRESS:
DEFAULT_GATEWAY:
IP_SUBNET_MASK:
TFTP_SERVER:
TFTP_FILE:
Finally, if Nothing worked out: TRY THIS:
1. Format the Flash card by using the erase nvram command.
2. Reload the IOS image.
3. Change the boot variable to point to the new image.
4. Reboot the device.
PLS Rate if HELPS
Best Regards,
Guru Prasad R
7 Replies 7
guruprasadr
Level 7
Level 7
Format to Specify:
IP_ADDRESS:
DEFAULT_GATEWAY:
IP_SUBNET_MASK:
TFTP_SERVER:
TFTP_FILE:
PLS Rate if HELPS
Best Regards,
Guru Prasad R
Hi Guro
Thanks for taking the time to look into this for me.
I have a laptop directly connected to the router with ip address 172.15.19.2/30. The Router is 172.15.19.1/30 so what should I configure as the default g/w on the router? The TFTP_SERVER=172.15.19.2 is correct, eh?
It looks like this default g/w is configured wrong as the error message points out.....Missing or illegal ip address for variable DEFAULT_GATEWAY
Illegal gateway address.
Any comments on this?
Thanks again
John
HI John,
172.15.19.2/30 Subnet - IP Ranges as below:
Start IP: 172.15.19.1
End IP: 172.15.19.2
Subnet ID: 172.15.19.0
BroadCast ID: 172.15.19.3
INFO: Only 2 IP's are Usable.
This /30 Subnet is not Feasible for your current requirement. Kindly go ahead with /29 Subnet.
IP Ranges: 172.15.19.1 -to -172.15.19.6
Use 3 - IP's from the above /29 Segment.
Pls RATE / Vote if HELPS
Best Regards,
Guru Prasad R
Yes the only way I could get this to work was through another router. Could not find a solution with a direct connection.
One point to note is the file name: c2600-j1s3-mz.123-13a.bin
Note the .bin
Thanks for all the help!!
v.avagliano
Try th load of a small image through the consolle port (X-Modem procedure)
Not sure whether you people got it sorted out. But still it can work with the gateway specified as 172.15.19.1
Jay
I mean indeed it can work with direct connection.
Cheers!
