Suggestion on Cisco routing device
Joseph E Spoon
Hello. I am looking for a suggestion on a Cisco routing device that meets the following criteria. The goal is to have it setup in a redundant configuration with the same model router. I appreciate any suggestions.
  • at least 10Gbps or 25Gbps of throughput (25Gbps preferred)
  • can support at least 2 external ISPs via eBGP but preferably expandable to up to 4 external ISPs
  • can support at least 2 internal physical connections to the internal network
  • not near EOL
Some models that I've found so far that seem to fit the criteria are:
  • Cisco Catalyst C8500L-8S4X
  • ASR1001-X
  • ASR9001
If anyone has any experience working with one of the routing devices above or has any suggestions, I am open to it.
Leo Laohoo
Stick with Catalyst 8500.
Leo Laohoo
Great, thank you for the suggestion!
Leo,
Looks like it is but confirming that BGP is supported on the Catalyst 8500 switch / IOS XE software (https://www.cisco.com/c/en/us/td/docs/routers/ios/config/17-x/ip-routing/b-ip-routing/m_irg-bgp-pol-acct.html). Haven't had to chance to implement one of these yet.
Joe Spoon
The Catalyst 8500 is a router and can do BGP routing, HOWEVER, I must caution to be "smart" (aka frugal) about the memory purchased.
Nobody has ever got "burnt" for buying this router and then putting maximum memory.
