Suitable Router for GRE Tunnel and multicast
Dear all:
I want to know which Cisco Router with multicast an GRE Tunnel Interfaces is the chipest for a branch  and can do well to stream and receive Audio and Video with multicast protocols (PIM, IGMP).
Thanks a lot
Sergio
2 Accepted Solutions
rvarelac
Level 7
Level 7
Hi Sergio,
You can use the comparision table on the next link for a better reference of the Cisco products.
http://www.cisco.com/c/en/us/products/routers/buyers-guide.html#~branchkeyfeatures
The recommended models for a small office are 800 series or 1900 series, both supports virtual interfaces for GRE and multicast configuration.
Hope it helps
-Randy-
That's correct Sergio, those routers supports multiples types of VPNs ( S2S, VTI, DMVPN , ezvpn...) many of them use a tunnel interface for their functions, then yes they do support GRE, tunnel interfaces an IPSec as well.
-Randy-
6 Replies 6
rvarelac
Level 7
Level 7
Hi Sergio,
Hope it helps
-Randy-
Dear Ganesh and rvarelac, thank you for replying:
I checked the link and when a model says that support VPN, means support for GRE, tunnel interfaces and IPSEC,is this correct?
Sergio
-Randy-
Hello Sergio,
Randy won the race for replying..:)
Thanks Randy for answering..
-GI
Ganesh Hariharan
Hello Sergio,
Useful link provided by Randy, make sure to select product with future 5 Yrs growth increament in mind.
So that capcity is not an issue for network for future.
Hope it Helps..
-GI
aravinda099
Does ISR 4000 series supports GRE tunnels ? Also where can I find the maximum number of tunnles that can be created in a particular router model  ?
