Switchport going to Error-disable frequently which is connected to Hub
sivaalthi85
Hi Friends,
One of our swtich is frequently going to error-disable.
That switch port is connected to a hub and to that two PCs are connected.
Can you please suggest what is the problem and how to solve it.
Switch#sh interfaces gigabitEthernet 0/13
GigabitEthernet0/13 is down, line protocol is down (err-disabled)
  Hardware is Gigabit Ethernet, address is 503d.e508.4b0d (bia 503d.e508.4b0d)
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 20:09:59, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     1244435 packets input, 198757270 bytes, 0 no buffer
     Received 4177 broadcasts (252 multicasts)
     5 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 252 multicast, 0 pause input
     2293998 packets output, 2192224484 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Configuration for that particular port
interface GigabitEthernet0/13
switchport access vlan 43
storm-control broadcast level 20.00
storm-control multicast level 20.00
please Help.
Hmmm ... Do you see the result?
Shut/no shut the interface again and run the same commands. Make sure you wait for approximately 5 to 7 seconds.
If this is the same output then you MAY have a faulty cable.
31 Replies 31
sivaalthi85
I Have issued no shoutdown command and the port came up but afte sometime its again going to errordisable.
Please help.
Hi Siva,
You might have errdisable-recovery configured on the equipment, that's why the port got up without any manual action. Also you might have configure "storm-control action shutdown" which is one of the reasons that this is happening.
Dan
Hi Siva,
could you share the sh logs ouput.
Palaniswamy
Hi Palani,
Below is the output of show logging on switch
pr 24 14:43:25.971:  DHCPD: address 10.127.43.104 mask 255.255.255.0
Apr 24 14:43:25.971:  DHCPD: reason flags: timeout 3.108
Apr 24 14:43:25.971:   DHCPD: htype 1 chaddr 000f.fe1c.bcc2
Apr 24 14:43:25.971:   DHCPD: out_vlan_id 0
Apr 24 14:43:25.971: DHCPD: returned 10.127.43.104 to address pool Teviot_Comm_Vlan.
Apr 24 14:43:25.971: DHCPD: the lease for address 10.127.43.107 has expired.
Apr 24 14:43:25.971: DHCPD: Sending notification of TERMINATION:
Apr 24 14:43:25.971:  DHCPD: address 10.127.43.107 mask 255.255.255.0
Apr 24 14:43:25.979:  DHCPD: reason flags: timeout e.5906.79
Apr 24 14:43:25.979:   DHCPD: htype 1 chaddr 000f.fe1c.bd42
Apr 24 14:43:25.979:   DHCPD: out_vlan_id 0
Apr 24 14:43:25.979: DHCPD: returned 10.127.43.107 to address pool Teviot_Comm_Vlan.
Apr 24 14:43:25.979: DHCPD: the lease for address 10.127.43.101 has expired.
Apr 24 14:43:25.979: DHCPD: Sending notification of TERMINATION:
Apr 24 14:43:25.979:  DHCPD: address 10.127.43.101 mask 255.255.255.0
Apr 24 14:43:25.979:  DHCPD: reason flags: timeout 3.110
Apr 24 14:43:25.979:   DHCPD: htype 1 chaddr 000f.fe1c.c10a
Apr 24 14:43:25.979: DHCPD: returned 10.127.43.101 to address pool Teviot_Comm_Vlan.
Apr 24 14:43:25.979: DHCPD: the lease for address 10.127.43.109 has expired.
Apr 24 14:43:25.979:  DHCPD: address 10.127.43.109 mask 255.255.255.0
Apr 24 14:43:25.979:  DHCPD: reason flags: timeout 3.108
Apr 24 14:43:25.979:   DHCPD: htype 1 chaddr 000f.fe1c.c91e
Apr 24 14:43:25.979: DHCPD: returned 10.127.43.109 to address pool Teviot_Comm_Vlan.
Apr 24 14:43:26.390: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:43:29.410: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:43:31.423: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:43:32.967: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:43:33.973: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to down
Apr 24 14:43:38.411: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:43:40.676: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:43:46.296: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:43:48.402: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:43:50.709: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to up
Apr 24 14:43:50.709: DHCPD: interface GigabitEthernet0/13 coming up
Apr 24 14:43:51.715: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:43:55.515: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Hi Dan,
No its not coming up automatically. All the time I'm logging into switch and issuing Shutdown and No shutdown command.
then  it coming up for sometime and again its going to error-disable.
There is no Strom control coomand given to the switch.
Before it was configured with portfast and BPDU gaurd but I have deleted it because
Spantree port fast start should only be enabled on ports connected
to a single host. Connecting hubs, concentrators, switches, bridges, etc. to
a fast start port can cause temporary spanning tree loops.
Regrads,
Siva
Hey Siva,
it looks like time to time storm-control thresholds are being crossed over. Anyway, if you'd like the port to come up automatically, you can go for the global config command:
errdisable recovery cause
HTH,
Ivan.
Hi Ivan,
I have enable but still the port is flatuating.
24 14:46:03.643: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:46:08.097: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:46:10.874: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:46:12.879: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:46:19.682: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:46:21.695: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:46:23.490: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:46:28.465: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:46:35.763: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:46:43.480: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:46:50.787: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:46:55.736: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:46:57.045: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:46:59.058: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:02.179: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:04.192: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:06.440: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:08.453: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:11.557: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:13.570: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:17.144: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:23.343: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:24.929: %SYS-5-CONFIG_I: Configured from console by vty0 (192.168.18.27)
Apr 24 14:47:25.994: DHCPD: checking for expired leases.
Apr 24 14:47:26.992: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:26.992: DHCPD: interface GigabitEthernet0/13 coming up
Apr 24 14:47:27.999: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:33.191: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:37.268: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:46.328: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:48.333: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:50.203: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:51.260: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:53.265: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:53.265: DHCPD: interface GigabitEthernet0/13 coming up
Apr 24 14:47:54.280: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:56.134: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:59.884: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to down
Apr 24 14:48:06.570: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to up
Apr 24 14:48:06.570: DHCPD: interface GigabitEthernet0/13 coming up
Thanks Siva,
it is good that we have logs now, it is clear that storm-control is not a culprit here, otherwise it would have shown that is has kicked in. It could be a hardware issue on that specific port, but let's check what is connected to this port on the other end and what do we have in the logs there. To avoid hardware issue you could use a spare port on this switch instead of port gige0/13.
Awaiting your update!
Hi Ivan,
An hub is connected to this port and to that Hub two Pcs corrected.
If I connect the cable to other port on the switch same thing is going on.
basically two pcs connected to hub and from hub their a cable connected to Switchport 13
That's interesting Siva, thanks. I'd try these things(the order does not matter):
1) try to unplug one pc and see whether it will rectify the situation;
2) while the port is up, collect 'sh interface' output
3) run wireshark on one of the pc's - this will give you an idea what is going on in the wires;
4) try to play with duplex, for a hub it should be set to half;
5) remove storm-control knobs off the switch - I still suspect kind of storm due to a hub being connected;
Let me know how is it going.
HI Ivan,
Thank you so much for your time, I really appreciate.
I have couple of doubts on the steps you have suggested above. can you please breifly explain to me.
how to set half duplex on hub, its a 100mb hub and the port on switch is auto negogiate and the pcs connected to the hubs were auto nego but this morning i changed to full duplex but still problem is not solved.
I have no idea about the storm-control knobs . could you please explain. how to remove what is it actually used for
siva
Siva,
my pleasure!
4) I meant to hardcode it on the switch. Though autoneg is a good thing, it maybe wise to manually code it, at least to try;
5) you have those in the config :
gotcha?
Ivan.
Hi Ivan,
I'm pasting configuration for couple of ports below.
interface GigabitEthernet0/12
spanning-tree portfast
spanning-tree bpduguard enable
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
Apr 24 14:50:39.234: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:50:42.531: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:50:51.490: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:50:53.000: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:50:55.013: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:50:57.362: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:51:01.682: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:51:06.220: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:51:08.233: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:51:11.178: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:51:20.707: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:51:23.626: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:51:25.640: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:51:26.009: DHCPD: checking for expired leases.
Apr 24 14:51:28.123: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:51:30.136: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:51:32.250: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:51:36.805: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:51:40.664: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:51:44.875: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:51:46.259: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:51:48.272: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:51:51.082: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:51:55.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:53:26.016: DHCPD: checking for expired leases.
Apr 24 14:55:26.024: DHCPD: checking for expired leases.
Apr 24 14:57:26.031: DHCPD: checking for expired leases.
Apr 24 14:59:26.038: DHCPD: checking for expired leases.
Apr 24 15:01:26.046: DHCPD: checking for expired leases.
Apr 24 15:01:33.252: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/8, changed state to down
Apr 24 15:01:34.250: %LINK-3-UPDOWN: Interface GigabitEthernet0/8, changed state to down
Apr 24 15:01:36.624: %LINK-3-UPDOWN: Interface GigabitEthernet0/8, changed state to up
Apr 24 15:01:36.624: DHCPD: interface GigabitEthernet0/8 coming up
Apr 24 15:01:37.630: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/8, changed state to up
Apr 24 15:03:26.053: DHCPD: checking for expired leases.
Apr 24 15:05:26.061: DHCPD: checking for expired leases.
Apr 24 15:07:21.882: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 15:07:23.895: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 15:07:26.068: DHCPD: checking for expired leases.
Apr 24 15:09:26.076: DHCPD: checking for expired leases.
Apr 24 15:11:26.083: DHCPD: checking for expired leases.
Apr 24 15:13:26.090: DHCPD: checking for expired leases.
Apr 24 15:15:26.098: DHCPD: checking for expired leases.
Switch# show clock
15:16:08.829 UTC Tue Apr 24 2012
