Switchport going to Error-disable frequently which is connected to Hub
sivaalthi85
Hi Friends,
One of our swtich is frequently going to error-disable.
That switch port is connected to a hub and to that two PCs are connected.
Can you please suggest what is the problem and how to solve it.
Switch#sh interfaces gigabitEthernet 0/13
GigabitEthernet0/13 is down, line protocol is down (err-disabled)
  Hardware is Gigabit Ethernet, address is 503d.e508.4b0d (bia 503d.e508.4b0d)
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 20:09:59, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     1244435 packets input, 198757270 bytes, 0 no buffer
     Received 4177 broadcasts (252 multicasts)
     5 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 252 multicast, 0 pause input
     2293998 packets output, 2192224484 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Configuration for that particular port
interface GigabitEthernet0/13
switchport access vlan 43
storm-control broadcast level 20.00
storm-control multicast level 20.00
please Help.
31 Replies 31
fb_webuser
Level 6
Level 6
Check if err-disable for storm-control is enabled by doing the following:
NJ-SW#sh errdisable recovery | i storm-control
storm-control Enabled
If the output is ENABLED as shown above, please run the following command in config mode:
NJ-SW(config)#no errdisable recovery cause storm-control
and hit enter!!!!!!
Posted by WebUser Neeraj Jagga from Cisco Support Community App
fb_webuser
Level 6
Level 6
please run this command in config mode in addtion to my earlier post:
NJ-SW(config)#no errdisable detect cause all
Hi Web,
Switch#show errdisable recovery | i storm-control
Switch(config)#no errdisable recovery cause storm-control
Switch(config)#no errdisable detect cause all
Switch(config)#exit
Just given commands as you suggested
fb_webuser
Level 6
Level 6
After running the commands, please update if the err disable problem is solved....
I see you said you set the PC's to full duplex, that is incorrect, they need to be hard set to half duplex, hubs only work in half duplex. Also on the port that the hub connects to on the switch you need to also hard code that to half duplex NOT auto. This causes duplex mismatching and will cause the port to erro-disable.
Mike
Hi Burleyman,
I will try what you have suggested and I ll reply soon.
Thank you so much for ur time..!!!!
Hi Web Still the problem is not solved.
Please help
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
no errdisable detect cause small-frame
no errdisable detect cause loopback
no errdisable detect cause gbic-invalid
no errdisable detect cause sfp-config-mismatch
no errdisable detect cause pagp-flap
no errdisable detect cause dtp-flap
no errdisable detect cause link-flap
no errdisable detect cause l2ptguard
no errdisable detect cause pppoe-ia-rate-limit
no errdisable detect cause dhcp-rate-limit
no errdisable detect cause arp-inspection
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig (STP)
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause l2ptguard
errdisable recovery cause psecure-violation
errdisable recovery cause port-mode-failure
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause pppoe-ia-rate-limit
errdisable recovery cause mac-limit
errdisable recovery cause vmps
errdisable recovery cause inline-power
errdisable recovery cause arp-inspection
errdisable recovery cause loopback
errdisable recovery cause small-frame
Leo Laohoo
Something is not right here.
If the interface goes into error-disable then the first question I'd be asking is WHY.  To know WHY the port(s) went into error-disable then use the command "sh interface status error".
Next, if the reason is "link flap" (or something in that vicinity) then I'd consider running a TDR
Hi Siva,
try to do this things:
1) clear the counter of interface gi0/13.
2) set the speed and duplex w.r.t hub
3)observe the ouputs of " show interface" (multiple time) .
4) After that if port not stabilizes then try to remove the pc one by one.
Palani
sivaalthi85
Hi This morning output,
Apr 25 08:21:33.546: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:21:35.560: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:21:39.427: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:21:43.495: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:21:46.733: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:21:48.746: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:22:00.675: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:22:02.688: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:22:26.403: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:22:28.416: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:23:29.787: DHCPD: checking for expired leases.
Apr 25 08:24:07.083: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:24:09.096: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:25:29.795: DHCPD: checking for expired leases.
Apr 25 08:26:52.037: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:26:54.050: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:27:29.802: DHCPD: checking for expired leases.
Apr 25 08:27:50.514: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:27:52.527: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:28:05.890: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:28:06.896: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to down
Apr 25 08:28:11.267: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to up
Apr 25 08:28:11.267: DHCPD: interface GigabitEthernet0/13 coming up
Apr 25 08:28:12.274: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:29:29.809: DHCPD: checking for expired leases.
Apr 25 08:29:35.254: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:29:37.267: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:29:44.137: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:29:46.150: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:31:28.651: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:31:29.817: DHCPD: checking for expired leases.
Apr 25 08:31:30.673: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:31:33.072: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:31:35.077: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:31:39.942: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:31:41.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:31:52.189: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:31:54.203: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:33:09.557: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:33:11.571: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Harca_Teviot_Core#
Hi sivaalthi,
Can  please tell the model number of switch and hub.
Br.
Mohseen
HI Mohseen,
Its a layer 3 cisco switch and full duplex hub.
C'mon here.  Mohseen asked a very legitimate question.  Please answer appropriately.
I have the strange feeling this is a layer 1 issue.  One way of checking is TDR.
Sorry Its 3560
*    1 30    WS-C3560X-24P      12.2(53)SE2           C3560E-UNIVERSALK9-M
Ok. That's good. 3560X supports TDR.
1. Command: test cabl TDR int gig 0/13;
2. Wait between 5 to 7 seconds;
3. Command: sh cable TDR int gig 0/13;
4. Please post the output.
