Switchport going to Error-disable frequently which is connected to Hub
sivaalthi85
Hi Friends,
One of our swtich is frequently going to error-disable.
That switch port is connected to a hub and to that two PCs are connected.
Can you please suggest what is the problem and how to solve it.
Switch#sh interfaces gigabitEthernet 0/13
GigabitEthernet0/13 is down, line protocol is down (err-disabled)
  Hardware is Gigabit Ethernet, address is 503d.e508.4b0d (bia 503d.e508.4b0d)
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 20:09:59, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     1244435 packets input, 198757270 bytes, 0 no buffer
     Received 4177 broadcasts (252 multicasts)
     5 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 252 multicast, 0 pause input
     2293998 packets output, 2192224484 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Configuration for that particular port
interface GigabitEthernet0/13
switchport access vlan 43
storm-control broadcast level 20.00
storm-control multicast level 20.00
please Help.
31 Replies 31
HI Leolaohoo,
Interface Speed Local pair Pair length        Remote pair Pair status
Gi0/13    100M  Pair A     N/A                N/A         Not Completed
                Pair B     N/A                N/A         Not Completed
                Pair C     N/A                N/A         Not Completed
                Pair D     N/A                N/A         Not Completed
Above is the output
Hmmm ... Do you see the result?
Shut/no shut the interface again and run the same commands. Make sure you wait for approximately 5 to 7 seconds.
If this is the same output then you MAY have a faulty cable.
