switchport port-security limit rate invalid-source-mac EFFECT
Muhammed AKYUZ
If i apply this command to a trunk port which connects to switches, and it reaches to limit what is the action?
down the link  OR drop invalid mac-addressed packets?
Thank you.
sachinraja
Level 9
Level 9
Hi Akyuznet
It actually depends on what violation policy you apply:
switchport port-security violation{shutdown | restrict | protect}
with shutdown, it basically shuts the port, with restrict/protect option, it will not shut the port, but will drop the packets later...
Hope this helps.. all the best..
Raj
Giuseppe Larosa
Hello Akyuznet,
this command introduces a rate limit in number of invalid MAC addresses events on the port.
This is probably there as a form of defense from a possible denial of service caused by processing these events.
switchport port-security limit rate ?
  invalid-source-mac  Invalid source packet rate limit (packets per second)
switch(config-if)#switchport port-security limit rate inv
switch(config-if)#switchport port-security limit rate invalid-source-mac ?
  <0-1000>  Packets per second
  none      Disable invalid source mac address rate limit
it may help in keeping low the cpu usage. or it can be seen as a way to control the rate of  unsecure mac addresses on the port.
Hope to help
Giuseppe
Hi Giuseppe,
Can you suggest an ideal threshold rate limit value for 4507 switches?
Akhtar
