06-04-2007 11:50 PM - edited 03-03-2019 05:18 PM
I would like to capture the all packet in/out from one interface and forward to syslog.
How do I create ACL for it? how about the syslog server setting in cisco side? please advise
Bes regards
06-05-2007 12:25 AM
please specify your goals ... if you want to log infos from your router, see that:
http://www.brandonhutchinson.com/Remote_Cisco_logging.html
if you want to check all packets, the best way maybe could be a packet sniffer (like ethereal) and a SPAN port:
http://www.cisco.com/warp/public/473/41.html
Andrea
06-05-2007 11:01 AM
I would recommend to you that capturing all packets and sending out syslog is not the best way to accomplish what you are trying to do.
I would recommend using a sniffer or netflow to do this and not syslog.
