System returned to ROM by error - a SegV exception
edwin.sanjoto
Guys,
I have problem with the WAN Router 7206. It has been reloaded automatically 2 times since yesterday.
This is the output of show version:
Cisco IOS Software, 7200 Software (C7200P-ADVSECURITYK9-M), Version 12.4(4)XD11, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 03-Oct-08 15:52 by ccai
ROM: System Bootstrap, Version 12.4(4r)XD5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-KBOOT-M), Version 12.4(4)XD2, RELEASE SOFTWARE (fc2)
JKTPZBIIT1-6-WAN02-7206 uptime is 4 hours, 39 minutes
System returned to ROM by error - a SegV exception, PC 0x1E9ADA8 at 11:06:00 IND Thu Mar 17 2011
System restarted at 11:07:41 IND Thu Mar 17 2011
System image file is "disk2:/c7200p-advsecurityk9-mz.124-4.XD11.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Processor board ID 35461839
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.1
6 slot VXR midplane, Version 2.11
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 400 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
C7200 PA Jacket Card present in I/O slot (VAM2+ Encryption/Compression engine,)
3 FastEthernet interfaces
3 Gigabit Ethernet interfaces
16 Serial interfaces
1 Virtual Private Network (VPN) Module
2045K bytes of NVRAM.
250880K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
I have already put this message to the output interpreter and the solution is upgrading to the latest IOS. But, when I search in the Bug Toolkit about SegV problem, this bug status is still "Open".
So, how can I upgrade to the latest IOS if the status of this bug is still open?
                             CSCtj21237
       Unexpected reboot due to SegV Exception
                   Info                                    Information on this bug
                                Open                   2
Thanks for your help.
Edwin
edwin.sanjoto
Please upload the latest crashinfo file.
What were the recent changes on the device?
Rahul
