T1 DSU/CSU loopback question....
maxnpj
This might be the dumbest question of the day, but....if I telnet into a router then put the DSU/CSU into loopback (either "line loopback" / "line loopback payload" / "loopback remote full" / "loopback remote payload") ...will I lose my telnet session?
--Brian
Collin Clark
Brian-
Assuming your coming in across the T1 line, then yes you will lose your connection.
Collin Clark
Brian-
Yes...I should have specified, but I would be coming over the T1 line...and thank you for the answer. I figured that would happen...but I just didn't see it anywhere in documentation.
--Brian
FYI, if you schedule a reload first (in 20 min), you can initiate a loopback, run tests for 15min to the loopback, then the reload will put the router back in service so you can reach it again.
As a precaution....
1) save the running config before you start (if someone fixed something before, but didn't save it, reloading will blow away their change)
2) schedule reload
3) configure the loopback
4) test the T1
5) scheduled reload happens
6) telnet/ssh back in
