Bookmark
Subscribe
918
T1 line troubleshooting.
glynncounty
I have a problem with a T1 line. Here is a ping to the far router.
Reply from 10.48.29.2: bytes=32 time=2059ms TTL=254
Reply from 10.48.29.2: bytes=32 time=4ms TTL=254
Reply from 10.48.29.2: bytes=32 time=249ms TTL=254
Reply from 10.48.29.2: bytes=32 time=701ms TTL=254
Here is the show int serial0 on the far router:
Serial0 is up, line protocol is up
Hardware is PowerQUICC Serial
Description: Connected to GCITDR01 CKT#DHDG509029
Internet address is 10.48.29.2/30
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue 0/40, 3827 drops; input queue 0/75, 0 drops
5 minute input rate 0 bits/sec, 2 packets/sec
195467997 packets input, 1475903131 bytes, 0 no buffer
Received 2184243 broadcasts, 5 runts, 10 giants, 0 throttles
60589 input errors, 24505 CRC, 16830 frame, 0 overrun, 0 ignored, 19254 abo
rt
171951524 packets output, 2015792355 bytes, 0 underruns
0 output errors, 0 collisions, 144 interface resets
50 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Is there anyway that I can troubleshoot the serial card?
pciaccio
Level 4
Level 4
The first thing you need to do is reset all the counters on the router to determine how bad your errors are. You are receiving (or have received) input errors on the serial 0 interface. Try doing a SHOW CONTROLLERS SERIAL 0 command to look at the layer 1 statistics of the T-1. It will show you the alarms and errors on the T-1 itself. Also re-verify that you have all your DS0's configured correctly. Make sure that if you are supposed to be using a full T-1 bandwidth then you should have 24 DS)'s configured. Make sure that your Coding and Fraing for the T-1 are also configured correctly. Try performing a T-1 loopback onto yourself to verify if the errors are coming from within your building or from the carrier. Verify that the remote end is receiving errors or not. Once you have determined most of this information then you can start to pinpoint your point of failure...Good Luck...Pls rate...
bvsnarayana03
Level 5
Level 5
CRC errors appearing in the output. Get the link tested by ISP.
I reset the counters as mentioned above.. A little history on this T-1 line though is needed. At one point in time we had issues and bell south came out and checked it out. I believe the issues are gone now and were reflected in the counters since they have most likely never been reset. Reset the counters now i have the below..
Last clearing of "show interface" counters 01:29:35
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 1000 bits/sec, 3 packets/sec
5 minute output rate 1000 bits/sec, 3 packets/sec
32552 packets input, 6207500 bytes, 0 no buffer
Received 878 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
33748 packets output, 3840415 bytes, 0 underruns
I am going to try another serial intferace.. I believe we have a bad one that keeps getting moved around instead of being replaced.
