Cisco devices - Default interface delay values
Hi!
I've been trying to find an overall scheme for understanding what the default interface delay would be across an Ethernet switching network. Essentially I am trying to fix a network's routing so that redundancy between sites is achieved via EIGRP metrics rather then via manual administrative distance adjustments across all infrastructure. There is a long story here... but one that is not really important towards the point of this post.
Basically, when looking online I can't really see a definitive guide saying "Ethernet is 1000usec default delay". The best I could find is a support forum post (https://learningnetwork.cisco.com/thread/6116). My point is that when looking at Nexus switches and some (not all) interfaces on a Cisco Catalyst 3750 the default interface delay is 10usec rather then the 1000usec suggested elsewhere. As some examples I have the "show run" segment for some interface and the "show interface" section of the same interfaces:
interface GigabitEthernet2/0/5
switchport access vlan 700
switchport mode access
spanning-tree portfast
ip dhcp snooping trust
interface Vlan700
description Data-Server-01
ip address 10.150.1.1 255.255.255.0 secondary
ip address 10.200.0.1 255.255.255.0 secondary
ip address 10.150.1.252 255.255.255.0
ip helper-address 10.1.0.27
no ip redirects
no ip unreachables
ip pim sparse-mode
3750-CORE#show int gig 2/0/5
GigabitEthernet2/0/5 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 0026.0ab5.6d85 (bia 0026.0ab5.6d85)
  MTU 9000 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
interface GigabitEthernet4/0/24
no switchport
ip address 10.200.50.254 255.255.255.252
ip summary-address eigrp 1 10.0.0.0 255.0.0.0
3750-CORE#show int gig 4/0/24
GigabitEthernet4/0/24 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0026.0a95.f141 (bia 0026.0a95.f141)
  Internet address is 10.200.50.254/30
  MTU 9000 bytes, BW 1000000 Kbit, DLY 10 usec,
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
interface GigabitEthernet5/0/24
description Telstra Secondary WAN Link
no switchport
ip address 10.200.50.250 255.255.255.252
3750-CORE#show int gig 5/0/24
GigabitEthernet5/0/24 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0026.0a95.f159 (bia 0026.0a95.f159)
  Internet address is 10.200.50.250/30
So all of the above are from the same 3750G switch stack. The only pattern I can see in the above is that the 10usec NICs are "routed interfaces" and the 1000usec NICs are "switchports". In GNS I have a 3700 router setup and all NICs are 1000usec, granted it is a different platform (a router rather then a switch).
Anyone know what the pattern here is? Is there any reference documents that explain this clearly?
The reason I want to know is that EIGRP is in use for dynamic routing failover. I need to calculate delay across several links to provide a deterministic and non-load balanced routing topology (i.e. active/standby). I'm aware there are likely easier ways to achieve my routing requirements (OSPF comes to mind) but I'm stuck with a single AS EIGRP topology for the moment. Summarily, I just want to know about interface delay default settings.
Thanks!
Hello Jonathan,
Great, thanks for all that information..
Really appreciated it
Please mark the question as answered so future users having the same questions can use it.
Kudos for you
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
I figured it out by myself. It is an interface speed thing. The interfaces are 10/100/1000 capable. Depending on the negotiated bandwidth the default delay changes. Switchport/routed port has no effect. If you leave them "auto negotiated" then essentially the delay negotiates to match the port speed as per the below:
1Gbps = 10usec
100Mbps = 100usec
10Mbps = 1000used
I don't know what 10Gbps looks like but I imagine it is 10usec still. Below is some evidence from GNS:
R1#show int fast 0/0 | inc DLY
  MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
R1#show run int fast 0/0
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
end
R1#conf t
R1(config)#int fast 0/0
R1(config-if)#speed 100
R1(config-if)#^Z
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
It is important to note that changing the "bandwidth" statement doesn't change the negotiated "delay". Only the "speed" will change delay... but please note that changing "speed" command is potentially network impacting. The "speed" command changes the literal interface capabilities for negotiating link speed, whereas changing "bandwidth" and "delay" changes an imaginary representation of link throughput capabilities.
Anyways, there you go... hope someone finds this handy.
Hello Jonathan,
Kudos for you
Julio Carvajal
