tcl scripting ide
hi,
is there some kind of tcl ide where I could develop script and then just implement it on router?
br
balaji.bandi
You can use any CSR image on Virtual environment and test it i guess, again depends on the requirement.,
BB
ActiveState has an IDE that works for TCL as well.
What do you mean by 'just implement it on a router' ? Typically. TCL scripts need to be copied to flash.
https://www.activestate.com/products/komodo-ide/
