03-09-2023 04:09 AM
Hi!
I have a question. I want to set tcp mss adjust on specific interface on NCS 5501 router.
But after write command on interface the error is: "Platfotm doesn't support TCP MSS Adjust on this card.
Can i do something to turn on the mss adjust?
Solved! Go to Solution.
03-09-2023 07:20 AM - edited 03-09-2023 07:20 AM
Hi @marcinselewki95 ,
The tcp mss adjust feature is not supported on this platform. The following bug id (CSCvm25963) has been opened but I do not see any progress. Please contact your account team if this feature is required.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvm25963
03-09-2023 04:17 AM
I have not seen the configuration guide for MSS, you can only do MTU adjustment
by the way what interface you trying to adjust this ?
03-09-2023 04:24 AM
Thanks for quickly reply.
I try do this on Ethernet interface.
03-09-2023 04:35 AM
MTU can confg in L2/L3 port
IP MTU can config in L3 port only
IP TCP MSS can config in L3 port only
03-09-2023
05:23 AM
- last edited on
03-10-2023
01:16 AM
by
Translator
I try config tcp MSS on L3 interface but it doesn't work.
I can globally set mss using
tcp mss 1410
command. Is this command set mss globally on router?
03-09-2023 08:56 AM
Thank to very much @Harold Ritter
03-09-2023 09:09 AM
You are very welcome @marcinselewki95
03-09-2023 07:28 AM
the tcp mss globally effect the traffic originate from router not traffic bass through router interface.
so you need to config ip tcp mss in interface.
@Harold Ritter mention about bug I think it bug as he mention.
thanks
