Impact of applying ip forward-protocol udp port#
karamalomari
I have multiple Layer 3 SVI configured on the core switch and all of them are configured with
ip helper-address
command which by default enables
ip forward-protocol
Now we have a requirement to add
ip forward-protocol udp PORT#
command.
when using
ip helper-address
then following UDP ports are enabled by default:
1) TFTP-69
2) DNS-53
3) Time-37
4) Netbios name services-137
5)Netbious datagram services-138
6)BOOTP server-67
7)Bootp client-68
Tacacs-49
What will be the impact of adding
ip forward-protocol udp PORT#?,
Will this impact the default ports enabled by the
ip helper-address
method?
2 Accepted Solutions
NO
the new UDP port will add to UDP default port that router will forward it.
balaji.bandi
I do not see any effects - ip forward protocol
Enabling a helper address or UDP flooding on an interface causes the Cisco IOS software to forward particular broadcast packets. You can use the ip forward-protocol command to specify exactly which types of broadcast packets you would like to have forwarded.
If you use the ip forward-protocol command, specifying only UDP without the port enables forwarding and flooding on the default ports.
some reference :
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipapp/command/iap-cr-book/iap-i1.html#wp1776761080
BB
NO
rasmus.elmholt
Level 7
Level 7
No,
The new port will only be added to the list and if your SVI receives a packet on the port it will be forwarded to all the helper-addresses configured.
balaji.bandi
some reference :
BB
