TCP Reassembly queue overflow - Anything to worry about?
bill.morton
I am getting a few of these in my logs, do I need to take any action? Connection is PPPoE DSL.
009357: Jul 8 09:28:22.214 CDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:104330552 1492 bytes is out-of-order; expected seq:104304632. Reason: TCP reassembly queue overflow - session 192.168.1.21:1535 to 82.165.207.37:80
009358: Jul 8 09:29:15.898 CDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:3779234016 1492 bytes is out-of-order; expected seq:3779181744. Reason: TCP reassembly queue overflow - session 192.168.1.21:1543 to 216.27.14.71:80
009359: Jul 8 09:29:19.598 CDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:3785688738 1492 bytes is out-of-order; expected seq:3785662602. Reason: TCP reassembly queue overflow - session 192.168.1.21:1541 to 216.27.14.71:80
009360: Jul 8 09:29:21.914 CDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:3786173706 1492 bytes is out-of-order; expected seq:3786147570. Reason: TCP reassembly queue overflow - session 192.168.1.21:1541 to 216.27.14.71:80
interface FastEthernet0/0
description Link to the AK LAN 192.168.1.0/24$ES_LAN$
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
no ip mroute-cache
duplex auto
speed auto
no mop enabled
interface ATM0/0/0
bandwidth 3000
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0/0.1 point-to-point
bandwidth 3000
no ip redirects
no ip unreachables
no ip proxy-arp
no snmp trap link-status
pvc 0/35
pppoe-client dial-pool-number 1
interface Dialer1
mtu 1492
bandwidth 3000
ip address x.x.x.x 255.255.255.248
ip access-group OutsideACL in
no ip redirects
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname xxxxx
ppp chap password 7 xxxx
ppp pap sent-username xxxx
owillins
Level 6
Level 6
%FW-4-TCP_OoO_SEG : [chars]
Explanation TCP Out of Order packet processing queue related messages.
Recommended Action Increase the size of Out of Order packet processing queue size.
http://www.cisco.com/en/US/docs/ios/12_4t/system/messages/sm_ht03.html
a.alekseev
Level 7
Level 7
could you the output "sh ip traffic"
#sh ip traffic
IP statistics:
Rcvd: 39141763 total, 713575 local destination
0 format errors, 0 checksum errors, 0 bad hop count
0 unknown protocol, 0 not a gateway
0 security failures, 0 bad options, 0 with options
Opts: 0 end, 0 nop, 0 basic security, 0 loose source route
0 timestamp, 0 extended security, 0 record route
0 stream ID, 0 strict source route, 0 alert, 0 cipso, 0 ump
0 other
Frags: 0 reassembled, 0 timeouts, 0 couldn't reassemble
0 fragmented, 0 fragments, 0 couldn't fragment
Bcast: 523310 received, 0 sent
Mcast: 147115 received, 430468 sent
Sent: 568322 generated, 19659162 forwarded
Drop: 345 encapsulation failed, 0 unresolved, 0 no adjacency
0 no route, 0 unicast RPF, 0 forced drop
0 options denied
Drop: 0 packets with source IP address zero
Drop: 0 packets with internal loop back IP address
ICMP statistics:
Rcvd: 0 format errors, 0 checksum errors, 0 redirects, 14 unreachable
39 echo, 20 echo reply, 0 mask requests, 0 mask replies, 0 quench
0 parameter, 0 timestamp, 0 timestamp replies, 0 info request, 0 other
0 irdp solicitations, 0 irdp advertisements
Sent: 0 redirects, 11999 unreachable, 35 echo, 39 echo reply
0 mask requests, 0 mask replies, 0 quench, 0 timestamp, 0 timestamp replies
0 info reply, 0 time exceeded, 0 parameter problem
TCP statistics:
Rcvd: 9647 total, 0 checksum errors, 89 no port
Sent: 83240 total
UDP statistics:
Rcvd: 556750 total, 1 checksum errors, 510594 no port
Sent: 178694 total, 0 forwarded broadcasts
BGP statistics:
Rcvd: 0 total, 0 opens, 0 notifications, 0 updates
0 keepalives, 0 route-refresh, 0 unrecognized
Sent: 0 total, 0 opens, 0 notifications, 0 updates
IP-EIGRP statistics:
Rcvd: 147129 total
Sent: 294325 total
PIMv2 statistics: Sent/Received
Total: 0/0, 0 checksum errors, 0 format errors
Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0, Hellos: 0/0
Join/Prunes: 0/0, Asserts: 0/0, grafts: 0/0
Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0
Queue drops: 0
State-Refresh: 0/0
IGMP statistics: Sent/Received
Total: 0/0, Format errors: 0/0, Checksum errors: 0/0
Host Queries: 0/0, Host Reports: 0/0, Host Leaves: 0/0
DVMRP: 0/0, PIM: 0/0
Queue drops: 0
OSPF statistics:
Rcvd: 0 total, 0 checksum errors
0 hello, 0 database desc, 0 link state req
0 link state updates, 0 link state acks
Sent: 0 total
ARP statistics:
Rcvd: 522624 requests, 557 replies, 0 reverse, 0 other
Sent: 866 requests, 143 replies (94 proxy), 0 reverse
#sh ip ips stat
Interfaces configured for ips 0
Session creations since subsystem startup or last reset 322894
Current session counts (estab/half-open/terminating) [0:0:0]
Maxever session counts (estab/half-open/terminating) [625:140:66]
Last session created 00:00:00
Last statistic reset never
TCP reassembly statistics
received 241611 packets out-of-order; dropped 50192
peak memory usage 121 KB; current usage: 0 KB
peak queue length 16
try this, it should bump up your counters and stop some of the false reports
ip inspect log drop-pkt
ip inspect max-incomplete high 8000
ip inspect max-incomplete low 7900
ip inspect one-minute high 8000
ip inspect one-minute low 7900
ip inspect udp idle-time 360
ip inspect dns-timeout 10
ip inspect tcp idle-time 7200
ip inspect tcp max-incomplete host 250 block-time 1
ip inspect tcp reassembly queue Length 128
ip inspect tcp reassembly timeout 10
