Terminate 2 ISP on Single router for L2L VPN
anthony.dyne
I wanna terminate 2 ISP on the same Router and dedicated for Site to Site VPN to HQ.  How to configure two default gateway for two ISP connection
Both IPSEC VPN tunnel will point to HQ, currently one ISP is terminated on the Router and L2L VPN with HQ is ok
Hope to get some help
Config
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
crypto isakmp policy 10
encr 3des
hash md5
group 2
crypto isakmp key cisco address 85.12.x.x
crypto ipsec transform-set VPN esp-3des esp-md5-hmac
crypto map VPN8 10 ipsec-isakmp
set peer 85.12.x.x
set transform-set VPN
match address VPN
interface FastEthernet0/0
description Link_To_ISP
ip address 40.x.x.x 255.255.255.252
ip nat outside
ip virtual-reassembly
duplex full
speed 100
crypto map VPN8
interface FastEthernet0/1
description Link_To_ISP2
ip address 196.x.x.x 255.255.255.252
ip nat outside
duplex full
speed 100
crypto map VPN8
shut
interface FastEthernet0/1/0
description connected to LAN
duplex full
speed 100
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Vlan1
ip address 172.20.1.1 255.255.255.248
ip nat inside
ip local pool ippool 172.25.233.10 172.25.233.70
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 40.x.x.x
ip route 172.20.20.0 255.255.255.0 172.20.1.2
cheers
Anthony
Pawan Sharma
You can use the same router to terminate 2 ISP links but you wont be able to do load sharing when it comes to VPN tunnels. So, You can use IP SLA to configure failover on ISP links and VPN traffic.
Pawan S
http://www.ebrahma.com
Pawan Sharma
https://itgears.io
