Tftp issue with new devices (9300 & 3850)
ittechk4u1
Level 4
Level 4
cant copy the config files from these swicthes...
error logs
DC1XCIK1#copy startup-config tftp:
Address or name of remote host []? 192.168.19.8
Destination filename [DC1xcik1-confg]?
%Error writing tftp://192.168.19.8/DC1xcik1-confg (Timed out).....
I can ping tftp server and vice versa from laptop
ip tftp source interface is also configured...
what could be the reason..?
Thanks in advance
ittechk4u1
Level 4
Level 4
Now issue have been resolved by using the command;
"ip tftp blocksize 512"
I dont undersatnd why cisco says that "By default, the Catalyst 3850 uses a TFTP block size value of 512"
Thank all of you.
41 Replies 41
what do you use as TFTP server ? Make sure you have specified the correct folder on your TFTP server. Right now you arevtrying to save the file to the root of your TFTP server...
Jaderson Pessoa
Check if you mark correct folder and your tftp already configured to read and write.
Jaderson Pessoa
*** Rate All Helpful Responses ***
balaji.bandi
if this is windows 10 Laptop, check the it got built in FW enabled on windows 10. disable and try other option adding to other post.
BB
The original post tells this
Can the original poster clarify whether the device is able to ping the tftp server, specifying that the source address for the ping is the address configured as tftp source address?
Also can the original poster tell us whether after making an attempt to tftp the file there are any messages on the tftp server showing that it received an attempt to copy the config file?
I have had the experience with some implementations of tftp server that the file name must already exist in the directory that the tftp server will use (sometimes is the root directory as suggested in a previous response and sometimes is a directory specified in the tftp setup). It might be worth a try to create the file in the appropriate directory and see if that makes any difference.
If there is not progress toward a solution it might provide helpful information to run debug for tftp, attempt the tftp copy, and post the debug output.
Rick
Rick
Hi @Richard Burts ,
I do agree
with you
Best Regards
Sincerly Yours
Giuseppe
formerly known as giuslar
exd42062
Can you post the running config so we can see the settings of your switch?
here is the config from other swicth(9300)
no service pad
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging buffered informational
no logging console
no aaa new-model
clock timezone MET 1 0
clock summer-time MEST recurring last Sun Mar 2:00 last Sun Oct 3:00
switch 1 provision c9300-48uxm
switch 2 provision c9300-48t
ip routing
no ip domain lookup
ip domain name
no ip dhcp use vrf connected
ip dhcp snooping
login on-failure log
login on-success log
vtp domain xyz
vtp mode transparent
diagnostic bootup level minimal
spanning-tree mode mst
spanning-tree uplinkfast
spanning-tree vlan 1-4094 priority 24576
spanning-tree mst configuration
name pune
revision 1
instance 1 vlan -4094
spanning-tree mst 0-1 priority 24576
archive
path tftp://10.18.2.17/$h
write-memory
time-period 10080
username ......
redundancy
mode sso
vlan 1-4094
interface Vlan1
ip address 10.60.1.2 255.255.255.0
standby 1 ip 10.60.1.1
standby 1 priority 110
standby 1 preempt
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip tftp source-interface Vlan1
ip route 0.0.0.0 0.0.0.0 10.60.7.254
ip ssh version 2
logging trap warnings
logging source-interface Vlan21
logging host 10.18.2.18
snmp-server community cwlesen RO
snmp-server trap-source Vlan21
snmp-server location Pune
snmp-server contact Mr. test
snmp-server enable traps snmp authentication coldstart warmstart
snmp-server enable traps license
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps config
snmp-server enable traps syslog
snmp-server host 192.168.xx.xx v2
snmp ifmib ifindex persist
control-plane
service-policy input system-cpp-policy
ip tftp source vlan 1
still the same issue...
Leo Laohoo
So the process wrote something and then stopped.
I've seen this before and the issue is the TFTP server.
Can you try getting another machine to be the TFTP server?
1. I can ping from laptop to switch
2. I can ping from switch to laptop.
3. Used two other workstation/laptop, still the issue is same.
4. i can see the request coming to TFTP server .
Thanks in advance
the destination filename (Destination filename [DC1xcik1-confg]) does not match the file name in your screenshot, why is that ?
What is the hostname of your switch (doesn't show in your running config) ?
sorry ..
i just change the file name due to security issues..... FYI...it matches.
not sure if this has been answered before, but what do you use as TFTP server ? And what OS (e.g. Wndows 10) is the TFTP server running on ?
