The purpose of ip nhrp map multicast dynamic in DMVPN
Mitrixsen
Hello, everyone!
I am currently studying DMVPN Phase 1 and I have a question about the following command:
I understand that this is issued on the hub router/the NRHP server, but what exactly does it do? I was a little confused from the explanation that I've read
This command tells the hub router where to forward multicast packets to. Since the IP addresses of the spoke routers are unknown, we use dynamic to automatically add their IP addresses to the multicast destination list when the spokes register themselves.
And then we issue
ip nhrp map multicast nbma-IP
on the spokes.
This command specifies which destinations should receive broadcast or multicast traffic through the tunnel interface.
I am generally confused about this command. It specifies destinations that should receive multicast/broadcast traffic? But doesn't GRE support multicast and broadcast by default? Why is this
ip nhrp map multicast dynamic/nbma-IP
command even necessary?
Thank you in advance.
David
Hello
This command negate NHS the need to statically map to each NHC for multicast traffic, which will obviously cut down on the manual configuration of any new NHC being attached and misconfiguration, the additional command that would be required on the NHC would be to register itself to the NHS
( ip nhrp nhs  <tunnel ip of NHS> )
Kind Regards
Paul
7 Replies 7
M02@rt37
Hello @Mitrixsen,
While GRE tunnels can indeed carry multicast and broadcast traffic by default, DMVPN introduces complexity by dynamically establishing direct spoke-to-spoke tunnels over the hub. These dynamically established spoke-to-spoke tunnels are unicast tunnels and do not inherently support multicast or broadcast traffic between spokes. In a DMVPN environment, the hub router plays a key role in forwarding multicast and broadcast traffic between spokes. The hub uses the command
to learn about the dynamically registered spokes and can then forward multicast traffic accordingly.
Best regards
Hello
Kind Regards
Paul
Are both of these commands required for the NHC spokes? Or will either of them work and perform the same function?
AND
Hello
Yes they are or you can use the a more recent "all in one command" instead.
ip nhrp nhs <tunnel ip> nbma <nbma-ip> multicast
Kind Regards
Paul
Thank you, Paul.
Yes, I had seen that "all in one" command that combines the two in the DMVPN documentation I have been looking over. I have some old DMVPN static configs across my enclave that I am trying to clean up by switching to the dynamic setting on the NHS hub side and this all in one command on the NHC spoke side.
Rick
lachancp
From the spoke/NHC side when configuring this command, is the nbma IP the same as the tunnel destination (hub)?
Hello
FYI - the  NBMA ip will be the underlay destination address of the NHS (HUB)
Please note :You cannot use this "all in one command" if you intend to use clustering the DMVPM NHCs (spokes), as this command will be remove as/when you apply the cluster, so in that case you will need to use the old static mapping
Kind Regards
Paul
