The repeat log...
Soon Kwan Kwon
Hello all,
I have Cisco router 1921.
I configured like below.
conf t
boot system flash [IOS name]
reload
Whenever I power on after upper command, continuously came up like below commands...
What was worse, I cannot enter rommon mode even though I input "Pause Break"..
How can I deal with this problem?
Please tell me advice.
SK.
[The log when power on]
Smart Init is enabled
smart init is sizing iomem
TYPE MEMORY_REQ
Onboard devices &
buffer pools 0x01E8F000
TOTAL: 0x01E8F000
Rounded IOMEM up to: 32Mb.
Using 6 percent iomem. [32Mb/512Mb]
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
%SYS-6-READ_BOOTFILE_FAIL: tftp://255.255.255.255/flash:c1841-advipservicesk9-mz.124-17.bin No usable interfaces.
%SYS-6-READ_BOOTFILE_FAIL: tftp://255.255.255.255/c1841-advipservicesk9-mz.124-17.bin No usable interfaces.
%SYS-6-READ_BOOTFILE_FAIL: tftp://255.255.255.255/WORD No usable interfaces.
System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Copyright (c) 2012 by cisco Systems, Inc.
Total memory size = 512 MB
CISCO1921/K9 platform with 524288 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC disabled
Readonly ROMMON initialized
program load complete, entry point: 0x80903000, size: 0x4c4a0
open(): Open Error = -13
loadprog: error - on file open
boot: cannot load "flash:c1841-advipservicesk9-mz.124-17.bin"
IOS Image Load Test
___________________
Digitally Signed Release Software
program load complete, entry point: 0x81000000, size: 0x403d020
Self decompressing the image : ################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################## [OK]
2 Accepted Solutions
So what happens if the RESET BAUD button is held down for >30 seconds?
which serial console client you were using while accessing the routers?
16 Replies 16
Leo Laohoo
Someone may have incorrectly configured TFTP boot.
In ROMmon, post the complete output to the command "set".
Yes right, my junior staff configured by mistake.
What was worse, I cannot enter ROMMON mode... ㅠ_ㅠ
In this case, what should I do?
Thanks.
Pffft.  Why NOT?
This is an ISR G1 router, right?  A router with CF card?  If yes, then what happens if the CF is ejected and the router reboots?
No CF card...
The device I have is cisco router 1921..
Ok, read this: Baud Reset Button
hmmm.
I followed your link source.
But, continuously fell out... and continuously repeat again.
ha... how can I enter ROMMON mode...
The method that I enter ROMMON is press "Pause Break" right?
Ah, Leo!
I solved the problem.
I press "Ctrl+C" instead of "Break".
AND Following your link, I pressed Baud button when power on. FAILED.
even though I pressed over 30 seconds.
Cisco console + RS-232
I used them!
meaning - the boot has failed and if you are not able to enter the ROMmon mode ( try to console) if that does not work - the last resort is to raise a TAC with Cisco
I entered ROMMON mode by pressing "Ctrl+C" yesterday.
Thanks^^
Iulian Vaideanu
Level 4
Level 4
I don't think 1921 will ever run 1841 images...
thanks for replying, I'll check it out..!
