The repeat log...
Soon Kwan Kwon
Hello all,
I have Cisco router 1921.
I configured like below.
conf t
boot system flash [IOS name]
reload
Whenever I power on after upper command, continuously came up like below commands...
What was worse, I cannot enter rommon mode even though I input "Pause Break"..
How can I deal with this problem?
Please tell me advice.
SK.
[The log when power on]
Smart Init is enabled
smart init is sizing iomem
TYPE MEMORY_REQ
Onboard devices &
buffer pools 0x01E8F000
TOTAL: 0x01E8F000
Rounded IOMEM up to: 32Mb.
Using 6 percent iomem. [32Mb/512Mb]
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
%SYS-6-READ_BOOTFILE_FAIL: tftp://255.255.255.255/flash:c1841-advipservicesk9-mz.124-17.bin No usable interfaces.
%SYS-6-READ_BOOTFILE_FAIL: tftp://255.255.255.255/c1841-advipservicesk9-mz.124-17.bin No usable interfaces.
%SYS-6-READ_BOOTFILE_FAIL: tftp://255.255.255.255/WORD No usable interfaces.
System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Copyright (c) 2012 by cisco Systems, Inc.
Total memory size = 512 MB
CISCO1921/K9 platform with 524288 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC disabled
Readonly ROMMON initialized
program load complete, entry point: 0x80903000, size: 0x4c4a0
open(): Open Error = -13
loadprog: error - on file open
boot: cannot load "flash:c1841-advipservicesk9-mz.124-17.bin"
IOS Image Load Test
___________________
Digitally Signed Release Software
program load complete, entry point: 0x81000000, size: 0x403d020
Self decompressing the image : ################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################## [OK]
16 Replies 16
do you have access to cli once the router reboots?
if yes, check if the following command is present in the configuration
no service password-recovery to remove the command use
if not you are not using the break sequence correctly to gain access to ROMMON mode.
I cannot enter CLI and Rommon mode..
The log I posted was continuously came up...
What should I do ㅠ_ㅠ
